hi, all, I so just bought my second skyline last month, its 99 R34 GTT. the car came with a 3 inch FULL exhaust, a hks filter and teinz coilover suspension. Last week IS Motor Racing at Rockdale supplied and installed a G-readdy electronnic boost controller for me, did a tuning on the same day.(139.5 max power at wheel). The guy told me my car is pretty much in stock condition, and all the stock R34s are between 130kw - 150 kw, only brand new can do 206 kw, for a 10 yrs r34, any where between 130 - 150 kw is normal. then During the tuning, he tested 0.6 bar first, was ok. then he tried 0.8 bar twice, failed twice, the power or boost was like goes up then drop down. what he explained to me was the stock computer will cut the fuel off if over boosted and strongly suggested me to buy a power fc. At the end of day. the guy setted 0.6 as low boost, and 0.7 or 0.65 as high boost...
we all know 1 bar =14psi, so 0.6 = 8.4 and 0.8 = 11.2
my questions are
1. is 139.5kw sounds normal with above mods?? i searched Autospeed website, says there stock R34 can do around 140-150kw, then plus exhuast and filter can do 160-170, and 180-200 with power fc on top of all these. 139.5kw is just fxxk sad and much less, though i heard every dyno machine is different, differnt dyno machine can give you different KW.
2. anything wrong with the tuning?? stock computer should allow u to boost to a safe level without fuel cut, i searched formum, most of you can boost to 11 or 12 psi with same mods as i have.
dont know what happened to my car, really sad now, please help, thx for reading this, ai~~~~~~~ paid $18000 for a piece of shit
https://www.sau.com.au/forums/topic/258088-need-help-with-my-r34-gtt-plz/
139.5rwkw is 186.93rwhp
not bad really.......
throw on a fmic and get a safc2 piggy back ecu if your on a budget
or get a full ecu, will see alot more power
and 1 bar of boost is 14.7 psi
example
my car went from 90rwhp to 245rwhp with just a tune
Edited by R32 Driver
my questions are
So how the f**k did my completely stock r33 gtst s2 dyno 157kw atw. Took it to another dyno and it produced 155. i thought r34 produced more than 33's??
numerous things
different settings
different dyno
different ramp rate
different air temp
and so on
~10rwkw is nothing to worry about
it is a reasonalbe assumption a bog stock r34 GTT would make more power than a bog stock R33
this assumes same dyno, same dyno, same operator, same settings, same environment
the ones you are comparing would not be the same, therefore whilst useful to compare in a ~ range, not a %100 comparison science
my questions are
The 206kw quoted by Nissan is not rwkw but flywheel kw. Your R34 is probably a little low and you are absolutely correct in that different dyno's produce different power figures. As an example I have Nismo FMIC, Nismo Injectors, Nismo fuel pump, Nismo reg, PFC, Z32 afm, hks 2535, Tomei cams, Apexi pod filter and full exhaust system from turbo back and produce 210 rwkw @ .6 bar on a Mainline dyno but 247 rwkw on a Dyno Dynamics dyno. It's all in how they set up the dyno. Like the other guys say, get a good FMIC and ecu and then you end up like the rest of us ..... just feeding the addiction!
cheers and enjoy the ride
Muz
Edited by Muz
Yeh i would say get yourself a Front mount its prolly running quite rich once you start winding the boost up the computer just dumps more fuel to keep things safe. Doing just that made over 25hp difference on my 33 and i was able to run a little bit more boost it ended up running 178kw at the rear wheels on 10psi.
I have a 34 now running 8.5psi with a FMIC full exhaust Apexi pod filter flowed turbo and the same Greddy boost controller at the moment its running 173kw at the rear wheels but should be able to get much more just tunning the boost controller once i work out how to set it right.
Out of interest what settings did he put on your boost controller to get the max boost your running?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
