hi all.
i have a slight misfire at idle and was thinking of changing the plugs. coppers are $3 and platinums are $20. so basically i can change the coppers 6 times for one platinum change...
BUT...
are the coppers inferior in any way?
all i have heard is that they foul easier than the platinums. it would be great to hear accounts from people who have put coppers in an rb20det or rb25det and how long they have lasted and what they thought.
i have platimuns in now and they have been there for at least 15,000 kms maybe more as i have not changed them since buying the car.
also, i will hopefully be tweaking the boost in a few weeks - will this increase the chance of my older current plugs shitting themselves?
from what i have read is the part number (NGK) BCPR6ES or BCP6E ?
and please DO NOT say do a search. there was too much crap info to deciper through to find the answer i needed.
cheers for all your help,
Waz.
https://www.sau.com.au/forums/topic/25809-copper-plugs/
  • Replies 56
and another related question:
i have read some accounts of getting a miss after turning up the boost.
how common is this amoung everyone? or is this a smaller issue? from what i have read mainly R33 owners have been the only ones affected by this. (go the R32's!!)
https://www.sau.com.au/forums/topic/25809-copper-plugs/#findComment-547582
hi.
I have an RB20.
I run copper plugs.
Mine have been going for about 15,000kms so far and no problem.
I run 13 psi through an RB25 turbo and there is no miss.
My copper NGK plugs are gapped to 0.8mm
One other thing...
Copper is a better conducter of electricity than IRIDIUM or PLATINUM.
I won't bother going to an expensive plug.
If I have to change 2 sets of copper plugs to 1 set of platinum, then so be it.
still costs me a SH1T load less and better performance..
https://www.sau.com.au/forums/topic/25809-copper-plugs/#findComment-547776
The main difference is the platinum plugs (factory standard) are suppose to last 100,000kms, whereas the copper ones are 10,000kms.
(The platinum electrodes dont get eaten away as quick as copper so last longer..)
I replaced my platinum plugs at 75,000kms with copper ones and gapped at 0.9mm due to running higher boost, and i havent had any problems at all. That reminds me its probably time to change them...
If you dont mind changing more often get the copper ones...
i like copper ones because changing more often you can see the state of each cylinder by the plugs condition (too lean, too rich etc)
Oh yeah, what gtst said the copper ones are suppose to have slightly stronger spark.
https://www.sau.com.au/forums/topic/25809-copper-plugs/#findComment-547793
I took my stock plugs out at 50,000 to drop a heat range and drop the gap to 0.8. They were in ok condition, but definately showed signs of wear - not just a little, they were well overdue for a change.
I put in copper plugs (NGK BCPR6ES, 0.08mm gap) and they worked fine. They were just replaced when I fitted a larger turbo, and the dyno operator used iridiums. He reasoned that the finer electrode provided a more consistant spark over copper, and he also droped another heat range.
I dont think the extra cost is warranted, compare $3 per plug and $18.50 per plug. The coppers were still in quite good condition after 10,000 (better than the iridiums at 50,000) - but at around the cost of 1 iridium plug for a full set, you can change them every 10,000 and still be better off. It never hurts to change the plugs regularly.
https://www.sau.com.au/forums/topic/25809-copper-plugs/#findComment-548000
I'm still using NGK BCPR9ES, 1.1mm gap on my car and no problems as yet.
These are the same plugs I used for Melb Auto Salon (495 rkwk) and when we raced at Heathcote last (10.47@137MPH).
I'm going to move down to a 7 heat range plug though as 9 is a bit excessive.
https://www.sau.com.au/forums/topic/25809-copper-plugs/#findComment-548175
I've used 2 sets of platinum plugs in only 40,000klm, and my car isn't modded and doesn't run particularly rich.
Coppers for me for sure next time....for $20 all up just change em every 5000 with the oil....
https://www.sau.com.au/forums/topic/25809-copper-plugs/#findComment-548354
My biggest reasoning for choosing the iridiums over coppers are mostly due to the longer life of the iridiums.
Copper plugs tend to deteriorate noticably over time, even while the plugs are still good. eg, after 10000 or 20000 cold starting is a bit harder and economy is down a bit than when new. And because of the intake being in the way I didn't want the hassle of pulling it all apart everytime I had to change them.
But now I have the front-facing plenum it's not nearly as big an issue to change the plugs every 5000 or 10000, so I think I'll go back to coppers when these iridiums wear out.
https://www.sau.com.au/forums/topic/25809-copper-plugs/#findComment-548983
Originally posted by Buster
My car came with HKS S40 plugs
Syndeykid does that sounds right as when I looked at ordering more it stated they were for a 4cyl
S40 is equiv to a heat range of a 8 in the NGK line up and a 24 in the Denso line up.
The S denotes the plug style, they also have Si, SiL etc.
Where/who stated they were for a 4 cyl motor?
https://www.sau.com.au/forums/topic/25809-copper-plugs/#findComment-549003
I think that is why most people would go iridiums :(
https://www.sau.com.au/forums/topic/25809-copper-plugs/#findComment-549006
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
