  • Replies 56
Hi
I've got a R32 GTS4(Rb20DET) and I am using copper plugs too,
they are: NGK R BCPR6EY11 gapped to 1.1
My engines done around 160kms and the 1.1 gap is to big, runs a bit rough at idle. I think they should be gapped to 0.8 when your coils are getting a bit tired like mine. Just change them once a year, only $20.
I previously used NGK platinums, NGK with a heat range of 5, I had them in for about 50,000kms. I dont think they could handle the OPtimax fuel, probably been ok if I had one range colder. The insulation on a couple of plugs developed an orange colour and the car would not start properly sometimes.
I dont think the platinums are worth it either. It only takes an hour to change them anyway and like someone said earlier you get to see how the car is running, can look down plug hole and see if pistons are carboning up at all.
I spoke to NGK. They say for Skylines and 200SX's, the better copper plug to use over the BCPR6ES is the BKR6E(Y)s... I have a set of BKR7Es in my car and I can run wider gaps with them compared to my 10k old platinums....
i have noticed the difference between power of the spark of coppers to platinums, my car and a mates car were misfiring a lil on full boost, we both regapped our new plugs (mine copper his platinum) to 0.8 both cars ran great, but after a few months his developed a miss again? coppers are sweet
Originally posted by Steve
and you should never regap platinums from what I have heard, it is such a thing coat of platinum that 9 chances out of 10 you will stuff them.
that might explain why his car started to misfire again. as much as i'd love to pretty much never replace my spark plugs if i used platinums, but it think it just aint worth it, also does anyone know if platinums and iridiums work well in the r33/32s with australias 98 octane limited fuel as opposed to the 102 in japan?
well it has been done
i changed the plugs to BCPR6ES plugs and they run great. it took me about 2 hours to do (i didn't remove the intake pipe over the top of the rocker covers, i just loostened it. it made life a real bitch though for cylinders 3 and 4!)
BUT... it hasn't removed the miss that i have at idle.... grrrrrr...
i'm about to get some stuff to clean the afm and then give the ECU a reset so we'll see...
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
