Fs-- R32 Gts-t
Item: 1989 Nissan skyline 2 door
Website: this one
Item Condition: Bad points are: has hail damage on roof and boot (quoted $600 to repair) Fibreglass bonnet needs replacing, 2 front tyres need replacing soon due to wheel alignment out (all good now tho) Also the standard RB20 Gearbox is starting to get noisy! But still works fine
Reason for Selling: want a change, if i dont sell it ill finish it off!!
Price and Payment Conditions: Really just seeing who is interested, but for a price say $14500, willing to negotiate with serious buyer, or swap for R32 GTR with damaged engine and cash my way!!
Extra Info: RB25DET engine conversion done a month ago, wiring loom done professionally( all wipers/washers and AC works!!) Wolf 3D version 4 ecu, Garrett GT35R 0.82 exh housing, mounted on high mount stainless manifold. 38mm external gate with screamer, custom plenum chamber with XF throttle body. Custom 2.5inch stainless intercooler piping, 600x300x100mm front mount intercooler, custom 3 inch stainless dump/front pipe. 80mm cat back blitz NUR spec R exhaust, 4 inch intake with K&N pod. made 250kw at the wheels (or 331hp) on only 11 psi, 40 degree day at 30% humidity, made 240hp atw on only 6psi!!!. (i have the dyno sheets if anyone is interested), all it needs is a bigger fuel pump and injectors and will get close to 300kw!! Exedy 5 puck sprung center button clutch.
Has a GTR front bar,car is painted in a custom deep purple. has 19 inch starkorp Kaotiks in black with chrome lip, M spec brakes all round. Tinted windows.
Inside it has R32 GTR seats, nismo gear knob, HKS boost and oil pressure guages. Genuine nismo floor mat set!!
Pictures:
Contact Details: pm me here or call sms on 0406143946
here are some better pics of the dents on the roof.. the large ones at the back are from the bonnett fliping up on the old owner!! they can be easily pushed out by hand. the other ones are from one of the hailstorms that syd had a while back. spoken to a couple of dent removal places and the quotes range from $600-$800 for the lot. Ill get some more recent pics of the entire car soon...
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
