Hi,
So far ive avoided FMIC (installed r34 SMIC) due to having to hack the bumper and id rather keep the car looking facory. Was at JJR yesterday and bought a split front/dump pipe. he said some of the coolingpro intercooler (whatever the are) bolt straight up?
Are there any FMIC that could be recommended for a r33 gts25t which bolt up without dramas/hacking? Id rather a black one too is it possible. Sounds bizarre i know
i just rather the stealth approach to be honest. big shiny intercoolers bulging out the front look cool but just not my thing. I want efficiency without the attention..
Any recommendations?
https://www.sau.com.au/forums/topic/258104-r33-gts25t-fmic/
The cooling pro thing is a good price and option. I just put one in the stagea because I didn't want to hack anything up either (and the return pipe from most intercoolers goes over the top of the motor/fan too.
You can always paint it black.
I'm not 100% sure on the 33 gtst but in the stagea it wasn't exactly "bolt straight up" some of the brackets didn't line up properly so you might want to get a workshop to do it if you aren't confident with "adjusting"
https://www.sau.com.au/forums/topic/258104-r33-gts25t-fmic/#findComment-4438824
my front mount is bolted behind the rio bar and the piping runs through the factory holes under the air filter. I didn't fit it, so thats all i know about it. So yes its possible to set it up easy...except not sure how you would go about getting the intercooler piping for it they may sell them in that shape for that setup somewhere maybe.
https://www.sau.com.au/forums/topic/258104-r33-gts25t-fmic/#findComment-4439766
if you removed the thermo on the front of the rad or put a spal slimline on the coolingpro would fit behind the reo, but would need piping and bracket mods... full custom from raceradiators down here in melb could make up a full custom that needs no mods to fit :D
you get what you pay for
https://www.sau.com.au/forums/topic/258104-r33-gts25t-fmic/#findComment-4439935
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
