Hi guys, I posted this in another thread but it's a little obscure if anyone was wanting to find a how-to. I searched and found zip so thought I'd snap some pics of mine I did todday.
** I used two different size hole saws to cut the radii and simply used a cutting wheel to remove the rest. Lots of masking tape around the area to stop any damage from swarf.
Initially I mounted the pins, raised them a little to make contact with the bonnet and make a mark from inside. I then drilled a small pilot hole, and then masked on the template provided and went from there.
Measure six times, cut once I suggest! :thumbsup:
Made U shaped brackets to utilise an existing hole in the radiator support. The return down the front too to give some extra strength. Made these from 3mm steel. You can see I had to gring the bolt down a little to allow clearence.
This is the drivers side from under, nothing tricky really.
The passengers side was a little harder. I did this second to get the feel for it. This is a GTR bonnet so I hade to carefully remove some of the reo.
And the finished product! A bit of fine tuning is needed to get them just right, and it's very strong, not going anywhere. As a bonus the rubber stoppers they supply were the perfect length to allow a little preload so no rattles.
And a reminder that angle grinders with cutting wheels can bite.
https://www.sau.com.au/forums/topic/258154-aerocatch-bonnet-pins-into-an-r32/
What a great read!! Came up really well...
I did the same thing 3 months ago, although mine is a fibreglass/carbon bonnet, so would have been easier to cut.
They work so well and look much cleaner than the old bonnet pin style..
Here's my finished result...
Was going to get my panel beater to paint them silver but he advised not to, paint might not stick properly and would most likely peel off from constant use...
Either way they're not as noticeable as the old bonnet pins, especially since it gets driven on the street...
i put these on my 32. the bonnet i used had all the supports cut out so i didn't have to make it fit around them.
the car also had had bonnet pins so i used the holes in the radiator support panel to fit mine but as you may have found it a bit to shallow under the bonnet to fit them so my bonnet which isn't real straight anyway doesn't quit fit flush. if i get a new bonnet i will install them the way you have.
oh and word of warning after a bit of work the lock in pins start to over balance and you need a tool to get them to lock down. i am not the only one to have run into this.
i got mine after seeing all the cars in targa tas last year with them and funnily enough your going in targa tas with some.
so these are regarded as street legal? Where did you get them?
yeah as they are flush fit on the surface of the bodywork most states accept these as road legal.
bensonmotorsports.com was the source for the woo... always in stock!
Nice one.
I have finally taken delivery of my carbon bonnet and a set of these bonnet pins.
I'm going to get Micolor to do it though as I would just mung it up if I attempted it.
Kudos to you for taking the time to do it yourself.
Regards
Andrew
Looks good, one of the more subtle ones which seems to suit the R32 better. How strong are the carbon bonnets with using Aerocatches. Is the carbon too rigid and brittle ?
No idea, it's got all the factory latches as well so it should hang together. the pins are only insurance.
great write up mate!
love these pins! so much tidier than the metal ones...
angle grinder = OUCH! hope your hand heals quickly...
I bought a set for my s13 a while back, but another "wooss" here
I took the easy way out (had my panel beater fit them while my car was in paint)
even he was nervous and he couldn't promise me a 100% guarantee on perfectly straight and flush fitment, but he nailed it first shot...
at first i was concerned they might bind up or become brittle, after sun/water/soap/dirt/dust etc but they are well made and with a tiny spray of wd40 stay nice and operable.
the only thing i could put them down for, is the pins themselves, they could be swapped out for some actual steel ones...
some pics from when i had mine done:
I tried to use some about 3 years ago but woosed out because i didnt want to cut up my GTR bonnet...maybe its time to second guess that decision :thumbsup:
lol, just bite the bullet Roy and do it mate, they look great and operate smoothly. I reckon they're the best part of the car now :D
Oh, guess what, the wheel Just turned up :D
If anyone needs it, i just made up a cutting/drilling template for the 125 Series, the one they supply is for the 120 series and slightly different.
Print it out full size and you should be sweet :(
Aerocatch_template.PDF
Ok, then where is the quickest and easiest pace to get them. Better shoot them off to the panel beater before the bonnet gets sprayed. Stuart?
They may look ok on my car since i am doing the fan boy black and silver thing :thumbsup:
Troy, got mine through revolution racegear, about $120 from memory....
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
