I was tossing up buying these or sparco pins when I first got my carbon bonnet on... I went the pins and slightly regret my decision :)
Oh well, that's laziness for you. Also, the guys at Revolution weren't 100% positive that I could line them up on the bonnet to sit perfectly flush but they hasn't been around that long at the time. Looks like they can be.
Looks good guys, but at what point doesnt the standard bonnet latch work?
Hi Mick, there's no problem with the factory catch at all mate.
I went with these for a couple of reasons.
1. I went to a GTR bonnet so rather than get the GTR catch panel or modify my original I got rid of the catch panel, catch, and cable alltogether. All that weighed about 3.7kg. Also aids in airflow to the radiator.
2. With the cage in my car it was very hard to pull the bonnet cable, so now the service crew can just lift it without me having to unbuckle and throw my neck out.
Ok, then where is the quickest and easiest pace to get them. Better shoot them off to the panel beater before the bonnet gets sprayed. Stuart?
They may look ok on my car since i am doing the fan boy black and silver thing :)
I did mine after the bonnet was sprayed Roy, no big deal either way.
Here's Stu's direct email; [email protected] , he could post them wherever mate. If you're talking to Russ again, maybe ask him if he has any spare sets, I remember he mentioned that a while back.
  • 2 months later...
Picked my car up today after getting the aerocatches fitted.
With the standard airbox it was a bastard of a job apparently. Thanks to Mick at Micolour it looks like a very neat job. It's the first time I've been there, he certainly knows his stuff. I'm sure I'll be back for some more car botox in the future.
post-21259-1243260939_thumb.jpg post-21259-1243261031_thumb.jpg post-21259-1243260999_thumb.jpg post-21259-1243261058_thumb.jpg
post-21259-1243261089_thumb.jpg post-21259-1243261117_thumb.jpg post-21259-1243261140_thumb.jpg
nice. What type/brand of bonnet is that Andrew? it's nice looking. :laugh:
It's a Varis "cooling bonnet" - I love engrish. www.varis.co.jp
Got it new through the Yahoo auctions at great expense (:banana: 60yen). The reason I chose it was because it has a neat little cover for the vent on the inside of the bonnet for when it rains.
Are bonnet pins necessary on a carbon fibre bonnet? I assume it's fine as is for road use, but i'm wondering about track day speeds if the wind can get under it and start flapping it around?
thanks mate.
and yes bonnet pins are very much a good idea on a carbon bonnet as they can and do flex when air gets underneath. even if they work with the factory latch at high speed air can get under and pull it out, or even break part of the bonnet so it's a much better idea to have it fixed at each side as well.
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
