Hi guys,
For Sale I have a Holset HX40 Steel Wheeled Standard Bearing Turbo Charger. Theses are typically used on MAN Mini busses however are also suited for High horse power applications.
The Holset HX40 has a T3 Flanged inlet on the exhaust housing and a 4 bolt outlet. the exhaust housing is quite big and allows good flow. The Airflow of the Turbo is is 0.53 (kg/s) . Note: this turbo will require a external waste gate!
The good turbo was removed from the vehicle it was fitted to because of broken exhaust studs in the output flange of the exhaust housing. i have since obtained another identical turbo with a blown oil seal and swaped the exhaust housings to make one good turbo and replaced all the retaining bolts. unfortunately it is not going to be suitable for the application i was going to use it for and i need to sell it.
i am asking for $500 for it and i throw in the one with the blown oil seal for free.
this item is pick up only. PM me for further details.
https://www.sau.com.au/forums/topic/258165-big-boy-holset-turbo-chargers/
