Cleaning out my shed
Contact: Lucas-0403468079 - dont mind if u send a msg
heres the list:
Bosch 044 3000km old-$160
R32 gtr drivers seat fit in r33 has a patch sewn over old tear $150
q45 afm meter with filter adaptor and silicon hose,yellow sticker, had 320rwkw-$200
r33 series 2 afm, 3 wire-$140
r33 series 2 coilpacks with loom (built in ignitors)- $90
r33 std injectors with rail and fpr - $90
r33 LH window reg - $50
r33 rear seats $50
r33 rear boot with s2 wing white boot black/gold pearl wing - $100
rb25 turbo elbow - $30
r33 hicas bar- $20
rb25/rb20 exhaust manifolds - $40
r33 ac compressor with hoses - $80
r33 rb25 ac bracket - $30
a/c thermo fan one broken mount - $20
LH rear vision mirror needs paint, white - $30
Blow of valve very loud and works well for a cheapy - $20
4 X r33/s14 etc rear camber and traction arms with camber bushes - $80
r33 washer bottle with motors - $10
std instument boost gauge map sensor - $10
r33 electric antenna - $60
r33 steering wheel - $20
R33 clutch fan - $50
I can supply pics on request as there is too many to put all of them on.
thanks
Edited by drf76
https://www.sau.com.au/forums/topic/258168-shed-cleanout/
I'll give u $30 for the Hicas bar if u drop it off at Sandgate Rd Albion?
just want to let everyone know the hicas bar is not a hicas lock bar just the standard stuff, so
speedracer33 is that what ur after, just wanted to clear that as there is a bit of confusion, my mistake
https://www.sau.com.au/forums/topic/258168-shed-cleanout/#findComment-4450548
    • Salut Frederick. Belle 370z. Welcome to SAU!
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
