Wheres The Lock Gone ?
hi all just did the s13 coilover swap and testeded out to day found out i had a lot less lock, than i used to and the the setup doesnt even have ne lock stops not to mention how much it made the whheels toe out .. ne 1 had these isssues ??
if ne 1 has done this conversion is there ne longer tie rod ends ? or something u can do or have i just f#$d the whole suspension geometry by doin this
ne help apprecited
thanks in advance
-harry
ne help apprecited
thanks in advance
-harry
Hi,
Did you want to tell us what you put the s13 coil overs into ?
A little information goes a long way, (well, I can't read your mind from this far away. :D )
Nigel
ummm you dont need longer tie rods, you just need to wind them out a bit further as in get a wheel alignment. As for steering lock I found no change really when I did mine maybe even a little more lock then usual. So I dont know whats wrong with yours.
Yup noted the same thing with mine after a wheel alignement it was fine, only thing i noted was a tad more bump steer from front end thats it really!
sweet thanks guys so i havent f@ d my D R, it still slid ok but yea i need agood w/a i did it by eye.... still felt like it lost a lil bit of lock, maybe my dodgy w/a has some thing to do with it ! but still curious is there a way to get more lock from this setup ?
My brother mentioned something about R31 tie rod ends for some more lock but i can't confirm weather it actually works or not though
yea i no i sound stupid id put the car togethr late saturday night, had no time to get a prpoer w/a ! booked in for w a this sat c how it goes..
r31 tie ends are differnt, they spin onto the end wereas the d r ends spin into the ends, wish that werent the case, swear ive seen a dr with longer tie ends some where just cant remember .. mabyb rack n pinoin conversion only way to resolve this...
cant change lock with tie rods. need 2 either shortern the steering knuckle or stuff around with the steering arms. rack n pinion is easier cos can space of the rack ends.
ive got s13 hubs/coils in my dr no dramas. never drove it with stock struts so unsure of lock changes?
arrr yes that makes sense, so a shorter knuckle id better ? i thought a longer knuckle would be the go? that was 1 of my concerns, the origanal knuckle is like an inch longer than s13..
From memory r30 ones dont quite fit properly either, but it's been a fair while since I played with that setup.
yep thats right i had to get the taper enlarged to suit, still doesnt seem right, the tie ends go into the knukle at a fair angle, thats why i thought longer tie ends would bring it back to a normal angle ..
ne ways got car w/a HEAPS better, surprisingly had it near 0 toe ! fluke ! camber was adiffernt story.. front end in the car seems spot on, just need to do something with the rear end, very loose ! ne 1 hear of eccentric bush s for rear a arms ? or ne way to get some adejustment ?
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
