Hi All,
Well its almost been a year of owning my stag. About this time last year I was hassling Mcnamg for pictures and info of his stag, via PM. I've loved owning the Stagea so much and have made many new friends and gained alot of knowledge on working on cars. First time I ever worked on a car was on the stagea and that was changing the timing belt! and doing 100k service! If your wondering. No this isn't going its time to sell ect ect! The next year will be a bit tighter with cash though as Im going to be a Uni student and not working full time.
'97 s1 silver rsfour, leather, No Spoiler :blink:
In the year I've owned the car ive made the following mods (all i can remember):
  • SAFC2
  • Greedy Profec B spec II
  • Apeix Pod filter
  • Cold air box and Cold air feed
  • Gab Wagon adjusrtable suspension (also tried ohlins)
  • 18" racing hearts
  • Adjustable camber arms
  • Adjustable toe arms
  • 3 1/4" cat back zhorst
  • Hi-flow cat
  • S2 tail lights
  • earthing kit
  • voltage stabliliser
  • HID lights
  • Front Mount IC
  • PWR trans cooler
  • Timer built into alarm
  • Lucas premium front pads
Before I got the car glen had done:
  • Splitfire Coilpacks
  • .8mm gapped platinum plugs
  • clear front and side indicators
  • Alpine headunit and splits
Does anyone have any mods or recommend i do anything in the next few weeks while im still making good $$$. Thinking maybe a gbox service and a shift kit?
https://www.sau.com.au/forums/topic/258240-its-almost-been-a-year/
i think your pritty much spot on with a shift kit, if your retaining the auto. the only other things left are a turbo upgrade, abit more involved ecu/piggyback like an EMU, or a manual converstion.
id also look at doing the fuel pump, the one you have is +10yr old. also an ajustable cam gear may give you a gain but there are other things i'd look at first.
i've heard the walbro 500hp intank ones are good unit, apparently there were some dodgy ebay ones getting around prone to failure but if you get one from a site sponser they are ok. you can get the kit for around $195. im looking into getting a new pump soon aswell.
DUMP FRONT IS THE BEST MOD YOU CAN DO and a highflow cat
JJR stainless dump/front heat wrapped and a catco 3" cat
picked up so much response and midrange, standard dump is almost flat over the wastegate area :thumbsup:
i agree. it just helps the engine and turbo breathe so much more. you can feel staight away how much better the car goes with them.
Just got a qoute on a shift kit, looking at $450 drive in drive out.
Funny you say that. Did the dump/front on a mates and he said he noticed the catback alot more. :S
i did do my cat too...
its a different sort of change, eg, when it coasts for longer when you lift off, less throttle to maintain speed on the fwy, builds boost quicker on the fwy
i then felt a little loss of response when i did my FMIC
upping the boost when i have the motivation to install my EBC.
FWIW I paid 395 drive in/out for my shift kit
ah Im going to grab a cheap $40 adjustable one (s13) and drill the ring connectors to suit :D
fmic looks funneh, should photo it.... no camera tho, soz. sitting under the reo bar - big :) no more spotties and cut the bottom dayz lip off ooops
camera phone and MMS to your e-mail addy
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
