Hey Guys
Just had my r32 gtr dynoed
R.I.P.S rb 30 billit main cap block
stock crank
argo rods
custom je pistons
rb26 head by rams
hypertune plenum
twin hks 3037s turbos
Car made 553.5kw at 4 wheels on shell 98 pump fuel
24psi boost it feels insane on the street makes full boost by 5000rpm
and pulls till rev limit 9000rpm
We still have nitrous and race fuel to play with so we will see how we go.
https://www.sau.com.au/forums/topic/258259-5535kw-at-4-wheels-pump-fuel/
  • Replies 165
Man that thing looks the ducks nutts! Great power and response for a set of 3037's to be making full boost of 24psi by 5000rpm, gotta love the advantages of the good ol ' fork lift ' rb30's over the 26 bottom ends. Got some more pics of the completed motor and car?
Cheers, Mat.
Haha nice work :thumbsup: If I remember rightly thats more power than a few of the 9s GTRs in Oz are running, just on 98 octane pump gas? Get some E85 and more revs (the dyno plot implies there is more useable power band to be had) and boost and some MT drag radials on that sucker and I can imagine some pump gas/street tyre records falling!
awesome work...good luck with it...another Silver Monster will be lurking out at WSID.
glad i did the upgrade now with all these tough cars coming out of the woodwork.
the tune looks to be still fairly fat...but at that boost on pump it needs to be...and why didn't they run it in shoot-out mode?
i have a question, i do not want this to be taken the wrong way at all. Yes its a very tough example of a gtr.
How would this thing drive ? say on a track ? or on the street, if your only over 350kw for 30 - 35km's in th rev range would it render the power useless and thus make the car really slow?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
