  • Replies 165
Im geting an auto 4wd box built out of a nissan cima.
Just want to be different so we will soon see how it goes
I know where you can get a 4WD T400 if you smash it as i looked at going auto but decided to stay with the manual.
Edited by DiRTgarage
In all seriousness, have you actually seen a finished TH400 4wd?
The reason I ask is I had a guy tell me he had one in his GTR and when I asked for pix he replied to say he'd made a mistke and his car was 2wd with a TH400.
I've "heard" of these 4wd TH400s but no-one seems to actually be able to produce evidence.
Rob
Rob
Ill take some shots this weekend...ok
australians build some of the best gearboxes in the world...why is it so hard to believe they cannot do it with transmissions Robbie?
These guys engineer some of australia's best street and show cars so i don't at all question what they have achieved. Mick Stanic from Subzero also has done a T400 GTR box although ive not seen that one 1st hand.
Man, your danglies must be really playing up, lol. Relax and read my question in a positive way as a genuine question, not that I'm on your case or calling you out, geeeeeez.
I didn't say I didn't believe you, I mearly wanted proper confirmation that a TH400 4wd had been done because the only ones I'd heard of turned out not be real.
Any pix or contact info of the guys who've done the trans would be greatly apreciated.
Rob
ive seen the box mick stanic had but it was a 4wd powerglide not a th400 just looked like a glide with an oem gtr transfer case adapted,it seemed to work fine in his street gtr.it might actually be the same gearbox that went into marios 8 sec gtr in dubai.
Hahahahaha until I read this I didn't realise there was a cunning stunt performed, awesome :D
BTW, it occured to me that this power figure is the highest I've read about on a Dyno Dynamics running 98 without nitrous.... gotta be up there?
ant ND4SPD in WA ran 660odd rwkw no nos, i cant remember if it was bp98 or some kind of monkey juice
never the less it was on low boost, only 21-24psi or something stupidly low like that
edit: apparently was on jungle juice, ill ask him if he ran it on bp98 ever
Edited by Cerbera
^^^ i wonder how often he can enjoy that power.... other than powercruise.
A turbo that can ingest humans would not be fun to drive around on the street
I get annoyed with the lag mine has.... and its running stock twins
A 500 or 600ps combo for a street/occaisional track warrior would be much more enjoyable to drive around town
But at the end of the day i guess he built it just to crank massive HP figures
his car makes full boost by 5000rpm and pulls hard till 9000.
how can that not be fun?
my mate runs a gt3540 rb30 on his r34 and makes full boost by 3900 and pulls to 7000.
he makes around 350rwkw. and has yet to even lose to anything on the street. and trsut me 20psi by 4000rpm is f*kn responsive on a big turbo like that.
we both know there are alot more serious cars out there.
but with a AWD system and full boot by 5000rpm. and making over 5000kw.
thats more fun then dreamworld
your profile says u own a r33 gtst....what stock twins are you talking about?
stock GTRs make full boost by 2500rpm but make like 250awk.......which is f*k all and isnt all that fast.
i can tell youve never been in anything other then your standard 2.5 or 2.6 skyline. this guys running a rb30 which will cause less lag and even more power. i dont think you know what lag is boy
Edited by VB-
Cheers for that, I thought it was 2 speed.
Hopefully dirt can get some pix and info on the th400 he knows of.
Rob
I drove my first 3L skyline a couple of weeks ago (with a pretty hefty turbo attached) and I have to admit, it was something else! Pulls like a freight train! Definately on the books for me :D
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
