we overlayed our circuit cars dyno chart with both power and torque against the GT-RS's on the drag car and you would swear it was the same car.
The low mounts at 22psi and the T04Z at 24psi...same power but the low-mounts power was made a little earlier and held on for longer...same with the torque...both are HKS powered cars but the circuit car was on Sunoco and the drag car was on BP98.
Wow interesting! What comparative engine spec? I'm not a fan of the T04Z and I am a fan of GT-RSs so I guess in my head its two better matched turbos against a dinosaur with a nice core. Any chance of sharing the overlay? It would help a LOT of people considering the options.
I wish there were more GT40-based setups on RBs to compare with.
  • Replies 165
There is more to this story though....the T04z was tuned to make every single KW...13.0:1 at 24deg GT-RS's were using a run in tune... 11.5:1 at 18deg.
Engines using STD cranks...87mm forged pistons...similar head porting and camshaft profiles (circuit 280deg drag 288deg)...both z32 power fc cars using blitz boost controllers.
Edited by DiRTgarage
Thats pretty interesting, with my main purpose using mine as a daily driver i want to be able to give mine a stab and not have to wait til the next set of lights before i hit boost....
thats why i'd be leaning towards 2.6 + GT3540 or RB30 + T04Z
i don't mind the -7's but they won't deliver the top end power that i know i will want in the future
i dont want to open up old wounds, legit question this.
the built bottom end from NZ costing was it $1200 cheaper then the one from Aus?
Anyway, question is, whats the shipping fees involved or do you have a warehouse over here?
Ive seen over seas shipping for software, it isnt cheap, i cant even imagine the price for a motor...
Also my other question is, if you guys can produce a turn key motor that runs 9s for 19k or whatever... how come it cost some guys 100k for their machines? i may be missing something here, but if someone could PM me the reasons or differences that would be appreciated.
Thanks,
Thanks,
100k - there is more to a "Machine" than the motor mate and some people also add how many times they have broken things / changed things to get there final $$$ figure
My motor was $450nzd shipping in a crate from RIPS in Rotorua - Melbourne Australia
Thanks,
cause i build my own and have my own machine shop...$19000 is just parts! But to be fair to Robbie...that was when $1 bought 100Yen. Same build would now be very expensive...if you care to look back a page or two i actually admitted i was wrong...which is a bit of a rarity on here for people to do even when they know they are wrong. When you look at it in today's money $19000NZD is about right.
Also it takes more than 1 build to develop a car to sub 10 times...im on my 3rd engine now to shoot for 8's, my 3rd turbo set-up, my 3rd different type of gearbox, my 4th type of clutch, my 2nd type of diff...shall i stop now?
You dont just tick all the boxes in the parts catalogue, bang it all together and go and run the numbers...it just doesn't happen that easy...i wish it did.
Not only did Mr Dirt admit he was wrong he also eluded the possibility of crossing to the darkside and playing with a dirty 30 :)
Edited by dano4127
i said increased capacity...i dont see anywhere where i mentioned robbing the trusty forklift of its power.
im building a 30 though...its gonna be big...its going in a VT Commodore wagon.
That could be why his nut sac is hurtin. They're growin.
nice one silver fox...ill pay that for sure
honestly i don't really find it financially justifiable to only increase displacement by 1 or 200cc it may make a difference however i have come to the conclusion that if i do stroke my 26 it will get some form of a R I P S RB30
interesting. I did look through the pages, and that is what i thought, that it would take a few builds to get the car running 8,9,10s etc. Just wanted check.
clear my mind a little :sick:
Should also say, gratz with the power. are you after track and drag times or just dyno power?
Thanks,
RIPS current shipping by sea rate is nzd600 which is still pretty good I feel except that any engines ordered this month or next get free shipping so its even better :-)
There's alot in building a quick car and the motor is just a part of it, we do have some very well proven combinations now where 10s, 9s, or even 8s with a very streetable motor is actually quite possible where the other areas of the car has been done correctly.
Rob
:glare: Don't tease like that!
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
