  • Replies 165
The bottom ends are $19000NZD...thats just the bottom end!!!
i dont even think thats for the ones with the billet mains paul!
but it does include a tomei pump, custom sump and other stuff
I am getting a gear box built so i will take it to the track once thats sorted out prob a month or so.
I brought the 4wd billit main cap block fron rips but the crank rods pistons and pump were mine.
The fuel system is a nismo lift pump a 5 lt custon surge tank with 3 x 044 pumps -10 fuel lines and sard 1000cc inj.
Brakes what are they? STANDARD a chute will pull it up ha ha ha na im going to put some alcons on it when i have the money.
Edited by superjet760
Excellent results there ;)
Can I just clarify though, did RIPS actually do the bottom end assembly, or just supply the block?
I take it from that your surprised? Remember our $ is very weak atm and they are usually under nzd17k. Whats a bare OSG shortblock worth these days? Then add all the stuff I list below and you'll be surprised.
If you actually start to add up the work and parts that is in one of my COMPLETE bottom ends you'll soon see it is actually very good value for money for a well proven product.
Its not just a short block, it has a block brace/adapter, custom high capacity sump, 1500hp front damper, tomei oil pump (over 3k on its own these days) billet rods, forged pistons, hours and hours of prep and machining, water pump, cam belt, all new idler, tentioner, lower cam drive gear, washers and keys, oil system mods, restrictors etc etc, all balanced to perfection and at least 3 days spent on prep, blueprinting and assembly.
I've had a few guys say they can do a better job for a lower price and when I ask them to show me or prove it or show me time slips, not 1 has ever got back to me.........very strange :-)
Rob
Edited by R.I.P.S NZ
What kind of maintenance would have to be done to keep an rb30 spinning at 9000rpm???? i would have thought that the harmonics and piston speed would decrease engine life by ALOT!!!
BTW: Love the twin 3037s looks awesome
Rob
we did my whole engine for $19000AUD...all JUN stuff...it ran 9's on its first outing...the same engine freshened up will go close to 8's on its next outing with new turbo set-up and proper gearbox. This is in a 1460kg GTR on street rubber.
Im not one of these internet mechanics who say things without the experience to back it up.
Not at all having a go at you...If you can get people to part with $19000NZD for a bottom end all the best of luck to you Rob. Well Done.
He did say just under $17k so thats like $13k AUD which leaves you $5k for the head and I take it you built your own motor too - this is the price he sells the short motors for retail as a business
Haven't seen anyone complaining about any of Robs products - his forklift motors are amongst the quickest around :)
just roughly adding that up in my head eats up $13k pretty quick - just because you can do it cheaper doesn't mean this package is not value for money
Edited by dano4127
I think what R.I.P.S do is great value.
I got a rb26 rebuild quote from a Certain Really well known Dyno tuning shop in sydney and almost fell off my chair,
$15k AUD, and that gets you no more power than one has to start with.
Awesome results. Thinking back to the late 90s a lot the mega quick GTRs were running twin 3037 and 3040s and running 9s on goat tracks that are Japanese drag strips.
With a good box and fuel this thing would have you empyting your bowels in a heart beat ;)
...and lets not turn this into another vs thread. :)
Yea awesome results, i was dead against RB30's but after seeing those promo vids and R.I.P.S website i am sold :) when it comes time for a rebuilt... a R.I.P.S RB30 is definately going to be part of it :/
I see what you did there lol.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
