  • Replies 165
i still havent got an answer about how you can keep the oil pumps alive with those revs on a rb30.......
who says it rpm that kills oil pumps? I've been over 10,000rpm with my RB30 lots of times with a conventional style oil system and wet sump
Rob
Rob
same...mine sees 9500rpm almost everytime its started...i reused my JUN pump as it had the faintest wear line down the drive face.
I would also like to know what mods are needed?
i had my 30/25 balanced within an inch of its life with lightweight skirtless pistons etc to get some revs out of it but would still be hesitant to rev to 9K just curious.
The R.I.P.S rb30 bottom end has billet main caps and over 75 bolts that hold the bottom end together.
A nitrided,cryoed crank,grub screwed and balanced and there you have it.
i dont know how u can count the sump bolts as bolts that tie the bottom end together, its actually only 51 if u use the rips "4 bolt" mains, 37 if u use the normal 4wd adapter. Total number with the sump bolted down is 79 with the rips "4 bolt" mains and 65 with the normal 4wd adapter.
Ok there are 51 bolts that hold the bottom end together.
Sorry :)
The sump adapter is made to suit the billet main caps. I dont think you can buy just a sump adapter plate but im sure Rob could confirm.
Edited by superjet760
Sorry :)
Its not actually. The sump adapter is made to adapt the 4wd sump onto an RB30. RIPS just incorporate the sump adapter into their "4 bolt mains" setup.
I make the sump adapters, rips make the sump adapters, pro engines make the sump adapters + more
Can i have one?
No i meant the billet main cap bottom end has a sump adapter but can only be used on R.I.P.S s billet main cap bottom end and you cant use this sump adapter with a standard girdle.
Im not sure if they make just a standard sump adapter like pro engines one.
Ahh k gotcha, yeh they do make the normal sump adapters
If you dont want to rev it hard just go for the normal adapter plate.
the bottom end will cost you the same as a 26 to build.
Adapter plate is somewhere around $1000
But if you want to rev it mine owes me about $14000 thats a R.I.P.S billet main cap bottom end.
we overlayed our circuit cars dyno chart with both power and torque against the GT-RS's on the drag car and you would swear it was the same car.
The low mounts at 22psi and the T04Z at 24psi...same power but the low-mounts power was made a little earlier and held on for longer...same with the torque...both are HKS powered cars but the circuit car was on Sunoco and the drag car was on BP98.
hey paul - was the T04Z or GTRS turbo's modified in any way?
ive always liked the idea of running twins on a gtr - the 2 'balls' of the godzilla!
The T04Z is an off the shelf HKS item. The GT-RS' were modified Red R Racing spec items.
Shanef, (with tounge in cheek) I'm so glad you know all about my products, what they can do and what they can't what they include and what they dont and what works with what and what doesn't, saves me alot of time, incredible :P (couldn't find sarcastic face, lol)
IMO the sump bolts play a key part in holding the whole deal together, you wouldn't be happy to let the sealer dry then pull out the bolts would you?
If you can spread load in any direction and minimise it at any point it has to be an advantage and the sump bolts are definatly to be counted as an integral part of the bottom end.
Rob
Rob
And dont forget the oil drain bung. (looks for same sarcastic face)
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
