hi guys have a nismo short shifter for rb25 gearbox. the plastic bit that sits at the bottom of shifter seems to shat itself and i need a new.
so i got a standard shifter got the plastic out of that trying putting it on the nismo shifter and it wont fit on.
so i called up a few places and they told me that nismo dont make that part and only sell them with the short shifter kits and was told i have to get one made up.
can someone help me out here plz
https://www.sau.com.au/forums/topic/258277-nismo-short-shifter/
That's weird man. You can buy the caps from a Nissan dealership. The shifters work on RB20 boxes as well as RB25's. The only difference between the two is the cap size is bigger on RB25 and GTR boxes, and the retaining bolts are longer on RB25/GTR.
The caps are only a few bucks so it's worth trying. You will need to give it a bit of pressure to fit them on as well. I placed the cap on the ground and pushed the shifter into the cap using a small amount of body weight.
I had to swap mine from the RB20 box to the RB25 when I made the change, and the ball was the same size between the two. Only the cap size differed.
Yeah ditto on all of that. While mine was a C's shifter though, the principles should be the same.. ran it on my RB20 box and then the 25t box.
I would also maybe find a short bit of pipe that fits nicely around the shifter bush as if you give it too much force to get the ball in you can destroy the nylon bush pretty quickly.. something around the outside of it should help keep it in one piece.
  • 3 weeks later...
i was about to buy a nismo short shifter for my r33 GTST but heard they can cause long term problems with the gearbox. Grinding etc. Is this true?
My brother has an 07 WRX with the (factory option however) STI Short Shift. It makes quite a difference in feel.
First I've heard.
I've had mine for 2 years with no ill effects so far.
  • 2 months later...
Hey all,
Searched the forums and this is as close as I have come to my problem.
I have a Nismo shifter in a 33gstst. For some reason whenever I am giving it a squirt and hitting around 6krpm or above and change from 2nd to 3rd, or 3rd to 4th the shifter seems to pop out of its housing? And I cannot find any gears? The shift distance greatly increases (like factory) and the car pretty much becomes undrive-able.
This has happened on a couple of occasions. The first time I took it to my mechanic and he just said the nylon bush needed replacing/repairing and it shouldn't happen again. Around 3 months later it has happened again. This time I took it apart myself, inspected and re-seated everything in hope it would be fixed, however no avail.
Is this a common problem? Can anyone point me in the right direction to know how to fix this? Preferably permanently.
Cheers,
Greg
It depends on how you drive. You can punish your gearbox with the standard shifter as well, its just that the sort shifter makes it easier to change gears more quickly. Lots of very fast changes will eventually take their toll. Dont drive like a dick and you'll be fine. :P
Great background info mate, however I am after a solution this doesn't answer my question.
Anyone know how to fix?
Cheers.
Cheers.
Dude did you see the QUOTE (Mattw_83 @ 15 Mar 2009, 12:12 PM) at the top? I wasnt answering your question...
But - have you got the correct internal circlip on yours? It shouldn't be able to pop out. IIRC it holds down a nylon "cup" that the ball on the shifter sits in.
if your talking about the half cup that the shifter sits in inside the gearbox housing and the plastic ring that locks the shifter in, try twisting the shifter and half to discover that the bottom half threads into the top half my idiot friend cut the plastic retainer ring to fit it over the ball end of the shifter instead of twisting it in half.
Mr Kotter, I did not see any circlip - maybe mines missing? I missed your quote earlier sorry mate.
Sukai, I will have another look at this when I get it off again.
Does anyone know why this happens? Poor shifter? I would have thought better of Nismo.
Thanks for the info guys, appreciated.
I also have this problem
I have a apparent r33 stock shifter that does the same as what Skydragon is having issues with.
Also have a stock r32 and stock s13 shifter available
The plastic cap on the end of the "r33" shifter is much larger and doesnt fit into the bottom of the s13 and r32 shifters...
I did a r33 box convo and never got a shifter with it :ermm:
Ok I havent got the r32 shifter handy (its bolted into the box and its cold outside, cbf pulling it out)
But this is what the r33 shifter looks like.
It seems the shaft that the smaller ball and nylon cup is too short for the box.
Its a good 10mm shorter than the r32 item.
The nylon cup from the r33 shifter also doesnt fit into the r32 shifter.
http://img189.imageshack.us/my.php?image=dsc00163y.jpg
Can anymore confirm that its the correct shifter?
Greets man.
That doesn't look like a short shifter. The throw should be longer than what I'm seeing.
The short shifter setup works by placing a bushing into the seat and extending the throw, compensating for the bush. The shifter sits on top of the bush. A cap is used to retain the shifter because it no longer sits inside the seat and cannot be retained by the factory circlip, it's also bolted down using C clamps.
The 20 box uses the same lever as the 25, the only difference being that the 20 box uses a smaller nylon cap, and the 25 uses a larger cap. The GT-R box uses the same cap and lever as the 25.
Yer I know its not a short shifter, but I was having the same problem with the plastic cup not seating properly and ripping the shifter out of the selector.
Also need a opinion if its actually a r33 shifter, not something else...
The nylon cup thing of that shifter pictured %100 does not fit onto the end of my R32 shifter :D
Replace the nylon cap, they're only about $5 from Nissan.
R33 and R32 shifters are the same.
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
