Does anyone know of a company here in Aus that sells 4 stud deep dish, looking for 15x8 and I guess
a 0 offset. Even a supplier in Japan that does'nt involve trying to decrypt pages of Japanese. Or if you've got some tucked away that your willing to part with would be even better. I don't want Wantanabes, but will consider other spoked items. I've looked at import monster and not much in there, quite like some of the hayshiracing mags but again it's that whole Japanese decrypting that is a Head F #@K.
I'd also like a simple Y or N to the C210 being a 0 offset. Cheers
https://www.sau.com.au/forums/topic/258301-4-stud-deep-dish-mags/
15x8 0 would be a good starting place. wouldnt be a hot boso fit but if your just going for a tidy street car thats where id start.. best bet is before you spend shitloads is to ask around on forums and test fit some wheels. importing is not feasable, and even people who own imported wheels want more now.
sportsmaxx make some decent sized wheels for the money. just under $900 delivered for a set of 15x8 0s
http://www.ae86drivingclub.com.au/forums/s...hread.php?t=804
alternatively there is superlites/ challengers but i recon the challengers belong on a XY falcon and the superlites on an escort. good sized wheels for the coin though.
heres some inspiration
Front: 14×8 -6 Rear: 14×10.5 -38 F: 175/60 R: 185/60
I think a zero offset for the front would be fine in an 8" but rears will need alot more negative offset to fill the guards(going from the above pic).
As for finding wheels, keep an eye on www.ae86drivingclub.com.au
often see wheels in decent negative offset pop up from time to time.
Edited by dsh4
Thanks for the info, my rear guards will be cut out shortly and flared fenders attached so no problem with fitting 8" rims. So 0 offset for front and back should be ok. Looked at ae86 tonight and there does appear to be a few rims like what I'm after selling there. Again thanks Ricky, Dsh4, are those Wantanabes? they don't look so bad. Don't suppose you post items from there do you?
Thanks for the encouraging responses guys, as i said in my opening thread I'm not so keen on the Wantanabe look. I've seen so many other mags on C210's all in Japan of course, so there must be a heap of different designs available. Probably just not over here.
Infiniteautosport.com.au I just found this site whilst googling sportsmax 002. They've got some ok looking rims. Mostly 2nd's by the look of it. Once again thanks for your helpful info. With each new reply I'm finding more and more rims and avenues. Cheers. Don't spose anyones seen some Indy style rims, the ones with hole instead of spokes, I do like this style. In 4 weeks approx I'll be selling my rims for $400, near new tyres on each rim post-44326-1235565084_thumb.jpg,
Message sent to Steve. Had a long think about this offset business last night, and dsh4 is about on the money. Looked in my C210 service manual last night and found that the offset is + 25, but that's for a 5' rim. If I'm going 8" or even 9" the offset is definately going to have to swing back into negative by a long way. Think it's time too seek professional help as I don't want to stuff this up.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
