just a quick question for those of you who may know what is the best diff for my 84 r30 and what cars can i grab one from. i have heard that subaru wrx's have r180 lsd's but do they bolt straight in and do the rear cv's have to be modified. also is there aftermarket alternatives that i can look at that mite be better suited. The cars original intention (before i bought it) was to drift and was equipped with a locker but i'm headed towards just all round tuning for daily driving and the locked diff is very frustrating if your not tryin to drive the car hard.
https://www.sau.com.au/forums/topic/258306-long-nose-lsds-to-suit-r30-skylines/
so yous is a r30? aka r180 diff? yes the sti subarus use a r180. normal wrx ones use a r160.( shafts/splines all differant)
unfortinatly the r180 lsd is evan more expencive than a r200 lsd. expect to pay 1500 just for the centre secondhand(rally use and fit anything nissan/datsun irs. hence the expence. ps(you will need to get it shimmed up as i stripped mine in my dr30rs. (r180 lsd)
you would be better off chasing a dr30 rs turbo rear end complete. same money but you have a r200 with bigger shafts and bigger rear brakes that use the same pads as a s15 200sx.
if you can find a late model one (84 up) comes with a 4.11 ratio not 3.9. and 14mm crownwheel bolts so all aftermarket skyline/silvia lsds bolt into the housing)
hope that helps.
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
