just a quick question for those of you who may know what is the best diff for my 84 r30 and what cars can i grab one from. i have heard that subaru wrx's have r180 lsd's but do they bolt straight in and do the rear cv's have to be modified. also is there aftermarket alternatives that i can look at that mite be better suited. The cars original intention (before i bought it) was to drift and was equipped with a locker but i'm headed towards just all round tuning for daily driving and the locked diff is very frustrating if your not tryin to drive the car hard.
https://www.sau.com.au/forums/topic/258306-long-nose-lsds-to-suit-r30-skylines/
so yous is a r30? aka r180 diff? yes the sti subarus use a r180. normal wrx ones use a r160.( shafts/splines all differant)
unfortinatly the r180 lsd is evan more expencive than a r200 lsd. expect to pay 1500 just for the centre secondhand(rally use and fit anything nissan/datsun irs. hence the expence. ps(you will need to get it shimmed up as i stripped mine in my dr30rs. (r180 lsd)
you would be better off chasing a dr30 rs turbo rear end complete. same money but you have a r200 with bigger shafts and bigger rear brakes that use the same pads as a s15 200sx.
if you can find a late model one (84 up) comes with a 4.11 ratio not 3.9. and 14mm crownwheel bolts so all aftermarket skyline/silvia lsds bolt into the housing)
hope that helps.
