If this has already been discussed can someone please point me to it as I cant find any info..
Im about to revert back to a t3 flange turbo from going down the td05 path and need to eigther buy a stock unmodifed manifold for my rb20 or get one of these cheap $350NZD ones (not spending thousands on a flash one) to accomodate for it..
looking for around 250kw+ atw with the new turbo just need some helpful advice on weather id see any gains with manifolds like these or just go for stock again:
http://www.trademe.co.nz/Trade-Me-Motors/C...n-203672556.htm
Dont care about the cosmetic appeal, turbo will most likely be gt3040 so opinions on top vs side mount am keen to hear any clearance issues etc..
thanks in advance.
Thing with those cheap manifolds is some work and some don't, some of them can make the turbo hit the bonnet or make the turbo push up against the rocker cover stopping it from fitting properly.
However friend has one on his RB20DET and it works fine, so just luck of the draw really.
Also, stay away from these manifolds -
They give no performance gains and without extra reinforcing they crack very easy.
Use the stock manifold. 250rwkw is nothing to ask from one of those. In fact they are better than aftermarket options in many ways.
I'm not going to get into a debate with other people on here about the pros and cons of cast vs steam pipe or stainless and short runner vs tuned length but I can tell you the stock manifold will have no flow restriction at those power levels and you will not notice any real improvement from merge collector designs on smaller power outputs.
yeah I have heard good things about the stock manifolds.. but what about the clearance mounting a gt3040 onto it? I shouldnt run into any issues should I?
but why do you want to use a GT3040 to get 250kw? a GT3071 or GT3076 is much better suited to the application and doesn't have the extra lag.
yeah true TiTAN, 250kw was basically the figure I wanted to get to but ill take anything over that 260, 270 who knows.. After going over the dyno results page it appears every gt3040 has easily over 250kw .. but having said that, most if not all of them have had bottom end work done, I on the other hand have not.. Id like to see more dyno printouts with the 3076 on an rb20 but have only seen one result at present, making 227kw if i recall but no printout.. I almost made that with the TD05, just dont want to run the risk of spending heaps on a new flash turbo if it isnt going to give me the peak output power im after. How much more lag are we talking about after all? I really have no idea how much sooner the 3076 will come on boost or weather I can gauruntee itll put me in the 250+ area
GT3040 or whatever is 600hp worth of turbo in its biggest form.
Thats over 300rwkw.
If you do not want that, and only want 260rwkw, get a 450-500hp item thats better suited to the job
I had a DSR one on my Skyline when I went GT30R and it ended up cracking - I got rid of the DSR manifold and have put a stock one back on and can't say I have noticed any difference though will have to hit the dyno at some point to confirm. I obviously prefer the stock manifold given it doesn't fall apart haha
sounds like ill be sticking with the stock option for now ... i find it crazy that these aftermarket ones can crack, I suppose its to do with them expanding and contracting all the time.. found another stock manifold for $75NZD hell of a lot cheaper than a dud aftermarket one..
Yeah these really do not like the heat cycling on a street car. If it was proper grade stainless it might work fine. And the weld at the collector seems to let go and burn the bonnet :thumbsup:
Yeah these really do not like the heat cycling on a street car. If it was proper grade stainless it might work fine. And the weld at the collector seems to let go and burn the bonnet ;)
Haha yeah I wonder where you've seen that :)
Redline performance sell a pretty cheap low mount manifold, one of which a guy I know of has used on his RB20DET powered S13 that goes VERY well (its running an EVO TD05 - its the same running gear from ADIDAN's R32 GTSt which was later crashed, Vanilla Rice) and that seems to work quite well, again unfortunately no dyno results yet but one thing I like about it is it happens to resemble little sketches I had been drawing and sending to people who can fabricate (alas I lack such skills) asking if it were feasable to make up, and if it would work.
Its essentially has two 3>1 headers and then 2>1 at the flange allowing something resembling proper collectors to be made up unlike most cheap low mount manifolds. It has the "tubular exhaust manifold" sound and feel to it and certainly hasn't lost anything over the stock manifold and most importantly hasn't cracked yet despite being street driven and run at 20psi so it could be promising. I have been watching with interest for a while.
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
