Ninja_09 Posted February 25, 2009 Share Posted February 25, 2009 Hi mate, I had the same issue some time ago, when I wind up the boost.... breaks/cuts off around 3.5-4K rpm and aroung 5.5-6k again.. re-gapped the spark plugs and issue fixed... I'd suggest to try that first (either re-gap or get a set of plugs that are already 0.8) Link to comment https://www.sau.com.au/forums/topic/258390-r33-gts-t-boost-cutting/page/3/#findComment-4444911 Share on other sites More sharing options...
syfon Posted February 25, 2009 Author Share Posted February 25, 2009 Hi mate,I had the same issue some time ago, when I wind up the boost.... breaks/cuts off around 3.5-4K rpm and aroung 5.5-6k again.. re-gapped the spark plugs and issue fixed... I'd suggest to try that first (either re-gap or get a set of plugs that are already 0.8) OK no worries i'll try that either tonight or tomorrow night and let you guys know if the problem is solved or not! I'm feeling more confident now that it's the incorrect plug gap Link to comment https://www.sau.com.au/forums/topic/258390-r33-gts-t-boost-cutting/page/3/#findComment-4444923 Share on other sites More sharing options...
FLN75S Posted February 25, 2009 Share Posted February 25, 2009 OK no worries i'll try that either tonight or tomorrow night and let you guys know if the problem is solved or not!I'm feeling more confident now that it's the incorrect plug gap That will more than likely be the problem i forgot about that when mentioning stuff before you are better of buying the cheaper ones they usually give you a better spark anyway but as already been said they def wont last as long i used to get around 15000kms in my 33 before they needed replacing. Link to comment https://www.sau.com.au/forums/topic/258390-r33-gts-t-boost-cutting/page/3/#findComment-4445494 Share on other sites More sharing options...
syfon Posted February 25, 2009 Author Share Posted February 25, 2009 That will more than likely be the problem i forgot about that when mentioning stuff before you are better of buying the cheaper ones they usually give you a better spark anyway but as already been said they def wont last as long i used to get around 15000kms in my 33 before they needed replacing. Oh well, sucks for me that i've just spent a shitload on platinum plugs *cry* Lol i'll go buy some copper plugs. Cheers Link to comment https://www.sau.com.au/forums/topic/258390-r33-gts-t-boost-cutting/page/3/#findComment-4445526 Share on other sites More sharing options...
FLN75S Posted February 25, 2009 Share Posted February 25, 2009 Oh well, sucks for me that i've just spent a shitload on platinum plugs *cry*Lol i'll go buy some copper plugs. Cheers Yeh that does suck dude nothing worse than buying stuff that isnt going to be any good lets hope this will fix the problem but id say more than likely it will. Link to comment https://www.sau.com.au/forums/topic/258390-r33-gts-t-boost-cutting/page/3/#findComment-4445536 Share on other sites More sharing options...
