I have downgraded to a K26 (the KKK (Blitz) model one down from this turbo)
No shaft play
Great Condition - It seems to have been rebuilt at some stage - but I don't know for sure.
Journal bearing - no water lines needed.
Polished compressor housing
T25 flange adapted to to fit either T25 or T3 flange
This Turbo made 312rwkw on an RB20
$500 plus postage
https://www.sau.com.au/forums/topic/258408-fs-kkk-k27-blitz-turbo/
Sorry - no dyno graphs - previous owner had these.
I can tell you on an FJ20ET (my motor) it started boosting at 3800 and full boost by 4700 - on a 2.5 or 2.6 or 3 Litre motor it would be perfect I reckon.
Great top end power - it's just 1000 rpm to laggy for me - which is why I downsized.
I reckon it would be equivalent to a GT3040
I don't have a close up of the ID tags - but you can see the blue KKK tags in the photos above - I can get close ups later
What do you mean by outlet snouts ?? The exhaust/compressor wheel size ? or the Manifold flange ? or the Inlet snout from intercooler ??
Dump pipe flange and you need and external wastegate - so either an adaptor between the turbo and the std manifold (not recommended) OR a new Exhaust manifold with external wastegate.
You would prob need to re-plumb/size your intercooler piping too.
This is a big turbo people - prob better suit a high/top mount than a low mount !
Please be aware - this is not Chinese/Korean KKR turbo
This is a GERMAN KKK turbo - same people who make Turbo's for BLITZ
The K26 that I have just put on my FJ20ET is a 320HP - THe K27 is the big brother of this turbo.
Here is the compressor map for the K27 - two actually....
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
