hey guys ive got these section spec RM/A8 coil overs on my 33, they came with the car when i bought them. Appanrently there fully adjustable but was wondering what do:
the little knobs on top of the coil overs do
what do 2 nuts do just under the spring
and what do the nuts do at the botom of the thread
my understanding from looking at the is that the top knob does the damper. how do you adjust it, with an alan key?
the 2 nuts under the spring, do they adjust the stiffness of the spring, so if i lowered that would make it a softer ride but would also lower the car.
dont kno what the bottom one does.
if any1 has any help on this it would be much apreciated.
Thanks Adam
https://www.sau.com.au/forums/topic/258418-coilovers/
Thanks Adam
The bottom nut is the lock nut for the base of the shock. Screw this out for more height or in to lower.
The two top nuts are for static sag. Do not adjust your ride height by playing with your sag.
The top knob does adjust the dampening for compression and rebound.
Start with removing the coilovers, with your car on suitable stands.
Set the two top nuts to seat the spring firmly in place, but not tightly to compress the spring. If the spring rate is correct for your car, you should only need to adjust it so the nuts firmly holds the spring in place. Adjusting this any more to increase ride height or reduce statis sag is just a bandaid fix. Make sure you have the right rate.
Next, undo the bottom nut and screw in or out the base of the coilover to raise or lower the ride height. Ensure the other coilover(s) is(are) set to the same adjustment. Put coilover back in car, measure the ride height ... remove and adjust again as necessary. If you need 10mm more, screw the base 10mm more out.
When you've got the correct ride height, take it to a wheel aligners and have the wheels aligned correctly.
Lastly, set the dampening to the middle-most setting. Turn it all the way anti-clockwise, now turn it clockwise and count the turns (or clicks). When at the end and you can go no further (do not force it), count half of the amount of turns/clicks out. Leave it at this setting. I doubt you'll have any need to adjust in the future.
Better still ... take it to a suspension place and get it done properly. :(
Edited by RubyRS4
https://www.sau.com.au/forums/topic/258418-coilovers/#findComment-4442874
Cheers mate
https://www.sau.com.au/forums/topic/258418-coilovers/#findComment-4442940
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
