  • Replies 44
I bought a cheepy, $350 ,that had a few problems with it (compressor wheel was eroded and exhaust housing was badly cracked) took it to per4manz turbos and cost about $600 to fit new compressor wheel and machine out second hand stock exhaust housing and new seals. bought some gaskets and fitted it myself , a easy job if everything comes apart ok. a bit more laggy than the stock one but heaps more pull when it gets going. went from 290rwhp at 12psi to 307rwhp at 11psi. aiming for about 350-360 at 17psi when injectors and ecu are fitted.
Edited by Pal
soo pal do you think that if i go with the $350 i will hav problems with ...
thanks for all the info its really good ..
if any1 has got a hi-flow for sale let me now ..... and if you hav got a r33 with same mods as me let me no power adn how much ti costs ..
thanks guys this forum is really good :)0
if you dont know the history of the turbo it's worth the extra coin to get it checked out before you buy it, and rebuilt if needed(making sure it is worth it first). not worth sticking it in and it popping on you. i put mine in just for seals and machining which was around 300 bux but due to the compressor wheel being stuffed, that put another $300 on it.
soo ppl is there any1 out there with a r33 that has a hi-flo .. wat boost are you on adn wat mods do you hav ...
on my car i hav a turbo back zorst , pod , cooler , fuel pump, and will be installing safc soon ... if i get a hi-flo turbo wat boost do you think will be safe for my car and would any1 know wat sort of hp ill be getting ..
thanks guys evry1 has helpd alot ...
230-240rwkw @ 16-18psi.
It's not so much "safe" boost levels as opposed to having a "safe" tune which will keep your engine alive.
Best (and safest) gains will be had with a proper ECU though. Probably going to max your airflow meter and not sure how an SAFC will go tuning past the AFM limits..
may get a bit more depending on turbo, i got 229rwkw at 11 psi with a safc2, hoping for 260 rwkw at 16-17 psi with injectors and full ecu
Edited by Pal
Yours must be a similar size to the hiflow on my stag then, 240awkw @ 12psi seems to be a bit more than normal 33 hiflows (mine is a hiflowed neo turbo so bigger exhaust housing). Some new injectors and ~18psi I'd hope to see ~280awkw.
mm not soo bad :) .... cant wait to get my car back on the road ...
duz any1 also know how much it costs to get the safc installed and tuned ...
i got safc1 is that crap or would itn help me a lil ....
and has any1 got a hi-flo for sale for a r33
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
