rev210 Posted February 28, 2009 Share Posted February 28, 2009 This rates up there with stupidest posts of all time. I appreciate your attempt at sarcasm with this post bubba but, you have to remember that the WA forum members mostly don't get it. Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4450854 Share on other sites More sharing options...
rev210 Posted February 28, 2009 Share Posted February 28, 2009 I've been using pliers to hiflow turbos for years. It's amazing how good the suspension feels after a good multigrip turbo hiflow. Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4450857 Share on other sites More sharing options...
Onthehunt Posted February 28, 2009 Share Posted February 28, 2009 Guys, Please stick on topic and contribute to the thread appropriately. Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4451440 Share on other sites More sharing options...
Pal Posted March 1, 2009 Share Posted March 1, 2009 (edited) I bought a cheepy, $350 ,that had a few problems with it (compressor wheel was eroded and exhaust housing was badly cracked) took it to per4manz turbos and cost about $600 to fit new compressor wheel and machine out second hand stock exhaust housing and new seals. bought some gaskets and fitted it myself , a easy job if everything comes apart ok. a bit more laggy than the stock one but heaps more pull when it gets going. went from 290rwhp at 12psi to 307rwhp at 11psi. aiming for about 350-360 at 17psi when injectors and ecu are fitted. Edited March 1, 2009 by Pal Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4452015 Share on other sites More sharing options...
r33-ml Posted March 3, 2009 Author Share Posted March 3, 2009 soo pal do you think that if i go with the $350 i will hav problems with ... thanks for all the info its really good .. if any1 has got a hi-flow for sale let me now ..... and if you hav got a r33 with same mods as me let me no power adn how much ti costs .. thanks guys this forum is really good :)0 Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4455618 Share on other sites More sharing options...
Pal Posted March 3, 2009 Share Posted March 3, 2009 if you dont know the history of the turbo it's worth the extra coin to get it checked out before you buy it, and rebuilt if needed(making sure it is worth it first). not worth sticking it in and it popping on you. i put mine in just for seals and machining which was around 300 bux but due to the compressor wheel being stuffed, that put another $300 on it. Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4456608 Share on other sites More sharing options...
r33-ml Posted March 11, 2009 Author Share Posted March 11, 2009 soo ppl is there any1 out there with a r33 that has a hi-flo .. wat boost are you on adn wat mods do you hav ... on my car i hav a turbo back zorst , pod , cooler , fuel pump, and will be installing safc soon ... if i get a hi-flo turbo wat boost do you think will be safe for my car and would any1 know wat sort of hp ill be getting .. thanks guys evry1 has helpd alot ... Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4471453 Share on other sites More sharing options...
bubba Posted March 11, 2009 Share Posted March 11, 2009 230-240rwkw @ 16-18psi. It's not so much "safe" boost levels as opposed to having a "safe" tune which will keep your engine alive. Best (and safest) gains will be had with a proper ECU though. Probably going to max your airflow meter and not sure how an SAFC will go tuning past the AFM limits.. Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4471499 Share on other sites More sharing options...
RICCA Posted March 11, 2009 Share Posted March 11, 2009 i GOT r34 with a S2 33 HigFlow atm running 1Bar Got a Full Turbo back Zaust , custom pod and stainless intake, FMIC, Good sparks plug getting my SAFC this week with a tune. Atm need fuel pump i think. Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4471506 Share on other sites More sharing options...
Pal Posted March 11, 2009 Share Posted March 11, 2009 (edited) 230-240rwkw @ 16-18psi.It's not so much "safe" boost levels as opposed to having a "safe" tune which will keep your engine alive. Best (and safest) gains will be had with a proper ECU though. Probably going to max your airflow meter and not sure how an SAFC will go tuning past the AFM limits.. may get a bit more depending on turbo, i got 229rwkw at 11 psi with a safc2, hoping for 260 rwkw at 16-17 psi with injectors and full ecu Edited March 11, 2009 by Pal Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4472050 Share on other sites More sharing options...
bubba Posted March 11, 2009 Share Posted March 11, 2009 may get a bit more depending on turbo, i got 229rwkw at 11 psi with a safc2, hoping for 260 rwkw at 16-17 psi with injectors and full ecu Yours must be a similar size to the hiflow on my stag then, 240awkw @ 12psi seems to be a bit more than normal 33 hiflows (mine is a hiflowed neo turbo so bigger exhaust housing). Some new injectors and ~18psi I'd hope to see ~280awkw. Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4472646 Share on other sites More sharing options...
Pattygtst Posted March 12, 2009 Share Posted March 12, 2009 Bubba what rpm do you get full boost at? Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4472985 Share on other sites More sharing options...
bubba Posted March 12, 2009 Share Posted March 12, 2009 (edited) About 4000rpm I think, maybe a *tad* earlier. Being auto with the stock stall (~2250rpm), makes it quite laggy off the line Edited March 12, 2009 by bubba Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4473096 Share on other sites More sharing options...
r33-ml Posted March 12, 2009 Author Share Posted March 12, 2009 mm not soo bad .... cant wait to get my car back on the road ... duz any1 also know how much it costs to get the safc installed and tuned ... i got safc1 is that crap or would itn help me a lil .... and has any1 got a hi-flo for sale for a r33 Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4473577 Share on other sites More sharing options...
bubba Posted March 13, 2009 Share Posted March 13, 2009 Yeah with a manual it would be fine, dial in some revs and drop the clutch But I've already got a 32 for that Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4475193 Share on other sites More sharing options...
Pal Posted March 13, 2009 Share Posted March 13, 2009 Yeah with a manual it would be fine, dial in some revs and drop the clutch But I've already got a 32 for that Yeh, tried that and had to clean my seat . Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4476261 Share on other sites More sharing options...
bubba Posted March 15, 2009 Share Posted March 15, 2009 Yeh, tried that and had to clean my seat . lol I like a good 2nd gear 5k clutch drop, lots of fun Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4479567 Share on other sites More sharing options...
r33-ml Posted March 16, 2009 Author Share Posted March 16, 2009 soo guys wat if i get a r34 turbo .. is it a bold on job and would i get a bit more power .. is so how much if any1 nos .. also who installs turbos fro a good price .. cheers guys Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4480414 Share on other sites More sharing options...
Pal Posted March 16, 2009 Share Posted March 16, 2009 a little bit but don't think its worth the money or effort 4 what gains you get unless yours has popped. workshops will charge around the $80 to $90/ hr. Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4480640 Share on other sites More sharing options...
r33-ml Posted March 16, 2009 Author Share Posted March 16, 2009 ohh yeah thats not soo bad .. how long duz it take to fit ... 3/4 hrs orr ... and teh 34 is a bold on job ???? Link to comment https://www.sau.com.au/forums/topic/258468-r33-hi-flow-turbo/page/2/#findComment-4480678 Share on other sites More sharing options...
