  • Replies 50
its definatly different, maybe a little our there for myself, sorta feels like it throws the lines out toward the rear where it has a bulge that seems too low.
Front looks like a mixture of a lancer front bar and the impul front bar for the r34
good luck sourcing the kit, if you ever get it be sure to post up pics!
https://www.sau.com.au/forums/topic/258491-hubba-hubba/#findComment-4443764
i can't believe they found a way to make an r33 even uglier
so are you saying r33s are ugly full stop?
evryones to there own i guess. the kit looks cool mate, not something id want but cool nonetheless.
GL finding it. might be a custom job
https://www.sau.com.au/forums/topic/258491-hubba-hubba/#findComment-4444143
ive seen this r33 on youtube. its the one with gullwing doors. i wudnt say it looks hot, different but not hot. those wheels gotta go!! the front looks like a prelude with a veilside kit :)
im thinking this kit was a one off
https://www.sau.com.au/forums/topic/258491-hubba-hubba/#findComment-4444176
its different,, thats what it is... with the number of skylines tht u see on the road today.. uve gotta do summin to stand out... :)... its def a custom job.. over the top yes... maybe i cud get summin made thts not too eye poking
https://www.sau.com.au/forums/topic/258491-hubba-hubba/#findComment-4444279
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
