  • 3 weeks later...
Hey..
How much for the Grille and thermo fan?? Thats if you still have them...
Im in Vic 3805
Cheers
I still have both
$30 for the grille
$50 for the thermo (blade pulled off the motor still works just needs a new nut)
And id say roughly $30-$40 freight as there quite big.
Do you happen to have the factory leather auto shift knob, if so how much delivered to brisbane?
i will have a look thru the pile and get back to ya.
  • 3 weeks later...
Bump
Will swap everything thats left (adds up to $2200ish) for a set of R34 GTR rims or something wide and nice offset, sick of the stock autech rims (which can be included in the swap).
Or someone just buy the lot and i'll do a deal, old man wants it gone from his shed, the "few months" i said it would take to get rid of it has been and gone.
still got the 02 sensor
i have a heap of 02 sensors, i am unsure if they work or not so not to keen on selling them on, best to get a new one, i think the EL falcons ones where the same just had to put ur plug on it, around the $70 mark?
  • 5 months later...
Hi mate, any chance you might still have the LHS mirror and black mounting arm (mainly after the black mounting arm)? Getting desperate to find one. Live in Brissy and happy to pay freight. Cheers.
All good, found one locally :action-smiley-069:
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
