Getting my front rotors replaced and rears machined soon ..so I thought I might as well get the master cylinder stopper installed but I'm not sure if this is even necessary for street driving or just racing where you might need to hit the brakes real hard ...?
Saw this one on ebay for $70 anyone used it? how's the quality ? Or should I just get the cusco one for $165 ? or none at all?
http://cgi.ebay.com.au/Skyline-R32-R33-R34...rts_Accessories
https://www.sau.com.au/forums/topic/258515-brake-master-cylinder-stopper/
I have a Cusco one, looks a lot stronger than that ebay one (has an arm that goes behind the strut tower, so 3 bolts in total).
I highly recommend the master cylinder stopper, it removes any vagueness so that any input you give to the brake pedal is used for braking.. not moving the firewall :)
If you are not going on the track don't bother. Only really useful on track with no ABS.
have one on my car, gets rid of the sponginess of the brake pedal. mine use to get all spongy especially holding on the brakes at red lights. firmer/more direct feel of braking. but like a couple have said, not essential
I have an R33 GTST - so perhaps different firewall strength to R34. I noticed a big difference in braking feel and pedal effort by fitting a brake cylinder brace. You won't notice the difference braking gently or in "normal" traffic driving but anything about 50% braking I noticed an obvious difference. Plenty of other people I talk to say the same. I decided to get one when I was bleeding the brakes - my GF was pushing the pedal and my master cylinder moved about 15mm with her pushing the pedal with high effort. That is a lot if you ask me.
+1
Also, although you cant feel it all that much, im sure the firewall is still flexing a little even with normal braking, over time that has to cause structural weakness where the booster is mounted to the fire wall.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
