Getting my front rotors replaced and rears machined soon ..so I thought I might as well get the master cylinder stopper installed but I'm not sure if this is even necessary for street driving or just racing where you might need to hit the brakes real hard ...?
Saw this one on ebay for $70 anyone used it? how's the quality ? Or should I just get the cusco one for $165 ? or none at all?
http://cgi.ebay.com.au/Skyline-R32-R33-R34...rts_Accessories
https://www.sau.com.au/forums/topic/258515-brake-master-cylinder-stopper/
I have a Cusco one, looks a lot stronger than that ebay one (has an arm that goes behind the strut tower, so 3 bolts in total).
I highly recommend the master cylinder stopper, it removes any vagueness so that any input you give to the brake pedal is used for braking.. not moving the firewall :)
If you are not going on the track don't bother. Only really useful on track with no ABS.
have one on my car, gets rid of the sponginess of the brake pedal. mine use to get all spongy especially holding on the brakes at red lights. firmer/more direct feel of braking. but like a couple have said, not essential
I have an R33 GTST - so perhaps different firewall strength to R34. I noticed a big difference in braking feel and pedal effort by fitting a brake cylinder brace. You won't notice the difference braking gently or in "normal" traffic driving but anything about 50% braking I noticed an obvious difference. Plenty of other people I talk to say the same. I decided to get one when I was bleeding the brakes - my GF was pushing the pedal and my master cylinder moved about 15mm with her pushing the pedal with high effort. That is a lot if you ask me.
+1
Also, although you cant feel it all that much, im sure the firewall is still flexing a little even with normal braking, over time that has to cause structural weakness where the booster is mounted to the fire wall.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
