Rb26dett - Oil In Turbo, Intercooler, Spark Plugs !?
Hi guys, here is a chain of events of my problem :
1)Experienced misfiring/engine stalling but no BLUE smoke.
2)Checked plugs to find them all oily.
3)Compression test OK.
4)Removed stock airbox - MAF sensors, Filter, Hoses all oily.
5)Removed hose at Turbo compressor to find a pool of oil contained there (refer to diagram).
6)Removed intercooler pipes - more oil flooded in there.
7)Removed Turbos to check - exhaust side is DRY.
8)Blowby control valve - need to check?
9)Turbo oil supply/return pipelines, hoses - OK, no blockage.
Engine is FULLY a stock setup (including crankcase vent. hoses and PVC etc.) except for the N1 oil pump and Tomei oil restrictor in the Block.Prior to the rebuild, piston #5 and #6 cracked, and I forgot to check whether that could cause a residue of oil in the intercooler, which I did not drain out.First thing came to my mind was that the Turbo SEAL could be defective, but on the other hand, the exhaust wheel is DRY.
Secondly, would the residual oil in the intercooler be re-circulated back to the intake/turbo??
Lastly, I suspected that the oil could leak past the new piston rings but that would be very unlikely because compression test passed and the exhaust ports on the cylinder head are dry.
I am desperately seeking ANY help or useful INFO out there,and I really don't know what else to check or do because I just bought the car. Thanks a million and I would greatly appreciate it...
CLean it all out manualy, im sure its blow by, i had it in mine and was stressed thinging id done a turbo, im guessing its in the rear turbo as well,
Get a catch can bruv and moniter it.. if continues ya blown a seal somewhere take stright to the shop avoid damage..
Check item 8 first. Make sure the thing works properly or you will have the problems you described. A failed blowby control valve will allow oil to get into the turbo compressor housing & leak onto the exhausts after a while. So, does the thing stink of oil when you are waiting at the traffic lights?
But yes if you cracked two pistons & didn't clean anything afterwards you may well have left over oil in the system. However it shouldn't take too long to for it to disappear. Mostly it just leaks out of the bov's.
Thanks for all the valuable advice and suggestions...I disassembled all the piping and cleaned out the entire system...plenty of residue oil in the recirculation tube! After flushing and checking everything mentioned, my engine now runs normally again. I am monitoring for any blowby in the meantime but have not yet fixed the oil catch tank...until really necessary.
I noticed this with my R33.. never thought anything of it, but have recently installed a catch can (blocked PCV and breathers vented to can) I cant say i recall smelling it anymore! Maybe mine was broken too.
I don't understand why people want to block up the blowby control valve when they fit a catch can. If it is done properly you still retain the functionality of the valve.
What if its broken?
I bought the can from RIPS in NZ, and they have alot of huge powered Skylines, i think a 1100HP Street legal R34 too. So i trust their methods :wacko:
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
