You must have had your baseball cap on backwards-sideways or some other blatant hoon behaviour.
Fight the powers!, I hope the judge gives the cop a serve for clogging the legal system with such frivolous crap.
What a joke.
i also said sorry for taking the courts time for such a small matter - the judge seemed to appreciate that
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4463657
  • Replies 66
to the police members on here ...............................
why is it that every ford focus barina etc that live in my local area that i see every day
have bald front tires and are clearly unsafe never ever get done like this?
I'm not a cop but I'll answer that.........it's called "Discrimination".
PS Well done for fighting the charge.
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4467047
because our cars attract attention. and becuase half the skyling drivers in the world are wankers that drift and skid on public streets?
it's shit, but it's easy to see how the stereotype came about. and let's face it. 4/5 imports pulled over are probably defectable.
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4474938
The other scam they pull is not having a spare tyre in the vehicle.... They tryed to pull that on me. I explained to them that I would take the fine and see them in court explaining to them that it is not a defect and they should pull over the new BMW's, Merc's and VW's as they come with a can of spray as the spare or a flat tyre straight tyre out of the factory....If you have a spare it must have legal tread (doesn't have to be pumped up) if there is no spare they cannot do a thing... Helps when you worked in the industry....They decided not to give me the fine and did a RBT instead funny that.....
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4476117
talk to your lawyer, thats what you've paid him for.
I have never been to court before, but presumably whenever you were going to ask for another 2 weeks, just say something like "the police have failed to provide me with the documents that I have requested and am legally entitled to and as such has wasted another one of my days, and more of the courts time. I wish to ask for the case to be dismissed so I dont have to waste more of the courts time in dealing with a bogus offense."
again, talk to your lawyer - i may have it all wrong ^_^
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4485319
ok good info
ill try bring this up in the morning
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4485651
Thanks matey
Unless you kick your lawyer in the arse and get him moving he will be quite happy to drag it out as long as the cops want to. Remember, He gets paid every time he does something on your behalf.
he may have you convinced that hes on your side but believe me, He isnt. He is on his side.
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4485713
oh nice
my lawyers ok
he advised me he doesent have to attend to adjournments to save me $$$
but i dont mind spending the money to see how this all pans out
it will be good for all of us to take a look at the system and decide if it will be worth fighting that misinformed bigot cop
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4485863
    • This issue has been there between twins and singles… it ain’t the hot side.
    • This actually makes more sense than what I'm suggesting, which would make me feel happier anyway. I just reached for an idea on the cold side because the tests on the hot side theoretically ruled out WG problems. But now that you mention it, it did bother me that a 12 psi spring on what is supposed to be a good WG setup is on able to get down to 20 psi. That's bullshit. Read that way, that WG is not doing what it is supposed to.
    • If you have a valve, set to 12PSi, and when it ramps up, it goes out to 23PSi, and then settles for a consistent 20PSi and thats the lowest it will go, then I'd be suspecting you have an issue getting enough air to flow AROUND the turbo on the hot side. Now, this could directly flow into what GTSBoy is saying, and that's effectively that your skinny ports aren't able to get enough of the air through the head. Remember, boost isn't a measure of air flow, it's a measure of restriction. And if the turbo at max bypass around it is still able to deliver more air than the head can ingest, your boost will be up.   In the NEO Head, being NA, you said it's stock, are you on stock cams, and stock springs in it?   Have you tried doing a run with the wastegate held fully open start to finish?
    • My theory would revolve around the ~4000rpm point being peak torque territory on an RB, where you're supposed to be looking at max efficiency of the head, etc, and....just not having it because the skinny ports are doing something to f**k it up. I'll admit, it's a loose theory.
