  • Replies 99
As my GTR32 is still at CRD I'd be pleased to drive your 33 to the display. But you have to promise not to tell anyone :) it's sorta of like taking one for the team.
Please PM contact details.
Has someone sent wheels an email about SAU attending? It's only a week away and I thought in the past, they liked a few weeks notice......
I've sent an email to them about the R31 club going, if you want I can send another reply letting them know that SAU is coming.
i will be emailing the events organisers very soon saying that SAU will be coming with about 15 cars. if anyone thinks that this is not enough then let me know. depending on where our spot will be allocated i'll try and organise a rough idea of a display which will more than likely be organised by model. eg: 32's, 33's, 34's etc....
John will kindly handle the drinks and money and hopefully mick will bring the federal tent. bring your own chairs if you want to sit down and dont forget your sunscreen :blink:
Thats great, thanks Luke. Mention some of your members are also affiliated with SDMA and see if they will put us closer together, not that its a biggie if they can't, but it was a good place for access etc.
John will kindly handle the drinks and money and hopefully mick will bring the federal tent. bring your own chairs if you want to sit down and dont forget your sunscreen :)
you forgot 31's...
Looks like i may be able to make this one for sure.
Can you leave a space for two cars please.
One is not a Skyline but it should fit in with them.
Also will meet out there so may need a phone number to contact someone so i know where to come.
Thanks
Hey guys!
Haven't posted for a while.
I'll bring my R32 gtr along under the proviso that my wifey doesn't go into labour
Will prolly get there around mid morning-ish...
Do we know what area we're in yet?
Oh, and a someone to ring to give me directions?
Cheers,
Brad
I'll try to be at the Calwell Servo at 8am. I plan to be at Wheels at 8:30am. Som is no longer driving his GTR but his R31 GTSX will be driven by his wife. I heard Graham with the R30 will be leaving Fyshwick with the R31 at 8:00 if you want to find him. They'll get to wheels around 8:15am-ish.
Sorry guys, Looks like I'm out.
My beautiful baby daughter was born this morning at 8:30am
Cheers,
Brad
awww congratulations Brad. There is no love stronger than a parents love of their child. I'm out too now... unless someone has a spare master cylinder floating around.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
