  • Replies 120
the guy copped it.. but he deserved it.. like 3 niqqas will go belt someone over a bag.. pulease? if you look in the video they were talking to him and swearing at him.... most likely say ing " why get cocky for ".. 23 was the guys age.. around the same as those niqqas
Moron.
People who resort to violence in retaliation to verbal insults are just proving their immaturity and their stupidity. People with half a brain can have an argument without resorting to violence.
Violence comes about because those attacking are either:
1) Unable to come up with a verbal retort due to their lack of smarts.
2) Wanted to beat someone up anyway, regardless of the reason, they just wanted to fight.
The first group are just uneducated idiots and often get frustrated or upset with themselves when they can't reply to something said to them so they vent that frustration but attacking the victim. The second group are just assholes straight up who don't care about others and have no place in our society. They should be hit with the full extent of the law, or if from foreign countries, deported.
I cant believe they would stoop that low. That video, i couldnt watch all of it.. it made me sick and angry. How can you justify that kind of violence? WTF IS WRONG WITH THEM?
Emsta, please keep updates on this. i would love to see who these 3 are .. and hope they get what is coming to them!
Please refrain from making racist and generally insulting comments. You've been warned.
for sure man - i have sent emails out, and hopefully when people see the video, they will forward it on, and eventually hoping that the public can assist in the arrest of the wankers.......If everyone sends emails out to their contact lists, we will get them!
This is as bad as those melton guys beating up that african dude......funny thing is they only got a suspended sentence or something.
would love to go one on one with that little prick in the white, almost like he was trying to fit in, noticed he always went back for the last hit.
think he looks up to the other two
and he was clapping too - thats just fckin disgraceful
I hope you one day are in the situation that this poor guy was...I hope you get beaten by the 3 same 'niqqas' and NO ONE helps you, because you deserve it.
hopefully the cops are true to their word about being close to an arrest and not just saying they where to aleviate any stress that may be in the community....in the footage you could see how tough they where though especially the tallest one going in to stick the boot in and missing and nearly falling then because he knew hed probably miss again if he tried to kick front on he moves to the side yeah his skills are mad....dipshits like this always pick the wrong person eventually and get bashed or stabbed
Edited by benkoau
^^ On that note, why would the 3 guys pick on the 1 guy..?
I just want to know both sides of the story...
There must be a reason..? Otherwise we all be out kicking each other asses.
OK there are some F**ked up ppl at the stations but its gota happen for a reason IMO.
Braybrook - no surprise there. I do IT work for a large NFP Organisation that provides services to the community in Braybrook. I had to go to site for an evaluation of the buildings cable etc. Man it was one hell of a sketchy place, pretty scary to be honest.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
