where are the BOVs located on an RS260 (R33 GTR)? and are there any bolt on upgrades for these?
cheers
I would assume they will be in the exact position any GTR would have them. Behind the front bumper ont he driver's side (RH side). I have never gone looking for them in a 260RS though so check there first.
Not sure on the upgrade options either but take some pics once you find them and I can tell you i they are GTR or not
Stock GTR BOVs = good for over 600rwkw & 30psi+
Good enough for everyone else :D
They leak @ idle as they are designed, it helps alleviate issues with comp surge and so on... there is a point to what some see as Nissan madness, so dont touch it
ARC and HKS make bolt-on replacements that can vent to atmo, so they go CCCHOOOOOOOO when you back off...its sick and you love it....although like Ash said this will cause your car to run rich once you back off and clutch in, if youve given it a gobfull it will probably stall.
AtomicBomberMan was selling some ARCs a while ago in the FS section.
GTR bov's are some of the best ever made...replacing these with anything would be a downgrade in my opinion.
what if you've just discovered that your gtr doesnt even have any bov's?
should i put standard ones on?
put the 2 aftermarket ones i have on?
leave it as is.?
what are the pros and cons of each of these?
i run a power fc..
wat about all the talk about the pressure being put on the turbo propellers?
hey as far as i understand bovs were put on cars by manufacturers to try and silence the fluttering noise caused by the boosted air across the compressor blades when the throttle is closed. I also believe that they did help prolong the life of the turbo as the air rushing back over the compressor can slow it down. anyone plz feel free to correct me
A bypass valve is a vacuum-actuated valve designed to release pressure in the intake system when the throttle is lifted or closed. This air pressure is recirculated back into the non pressurized end of the intake (before the turbo) but after the mass airflow sensor.
A blowoff valve does basically the same thing, but releases the air to the atmosphere. This creates a very distinctive sound. For some owners this is the only reason to get a blowoff valve.
The unique sound caused by a blowoff valve sometimes comes at a price. On a car the blowoff valve is mounted after the mass airflow sensor, so venting to atmosphere confuses the ECU. The ECU is told it has a specific amount of air in the intake system, and injects fuel accordingly. The amount of air released by the blowoff valve is not taken into consideration and the engine runs rich for a period of time. Engines with a manifold absolute pressure regulated ECU are not typically affected.
Typically this isn't a major issue, but sometimes it can lead to hesitation or stalling of the engine when the throttle is closed. This situation worsens with higher boost pressures. Eventually this can foul spark plugs and destroy the catalytic converter. When running rich, not all the fuel is properly burned in the cylinder which can allow unburned fuel to combust upon contact with and melt the converter or to cause incompletely combusted fuel to leave heavy carbon deposits.
Blowoff valves are used to prevent compressor surge. Compressor surge is a phenomenon that occurs when lifting off the throttle of a turbocharged car. When the throttle plate on a turbocharged engine running boost closes, high pressure in the intake system has nowhere to go. It is forced to travel back to the turbocharger in the form of a pressure wave. This results in the wheel rapidly decreasing speed and stalling. The driver will notice a fluttering air sound.
A blow-off-valve is connected by a vacuum hose to the intake manifold after the throttle plate. When the throttle is closed, manifold vacuum without pressure develops in the intake manifold after the throttle plate and sucks the blow off valve open. The excess pressure from the turbocharger is vented into the atmosphere or recirculated into the intake upstream of the compressor inlet.
I hope this clarifies any doubt you have as to it's purpose.
Later man!
Later man!
thanks for the info, very helpful..
so why is there even a such thing as atmo bov's if all they really do is release the pressure causing problems?
is it also possible that by having the atmo bov's wound tight that way only allowing less amount of air pressure out?
and in my situation my car has been tuned but continues to run quite rich, however doesnt have bad fuel economy, just blows a bit out the back.. so if adding atmo bovs makes that happen usually and mine is already does that mean it could be made alot worse again by adding them..?
Why are there things like iridium plugs? and so the list goes on :D
Just because someone makes something, doesn't mean its beneficial from a performance perspective. Some are for looks/attention and so on and offer no gain or even a hinderance
So is there in fact any evidence to prove that having a recirculating BOV is beneficial or offering any gains at all?
Also the A31 RB20DET did not have a factory BOV, whereas the R32 RB20DET did, I always thought they gave a slight performance increase due to the air charge not being forced back through the turbo or being vented to the engine bay.
i hav an r32 gtr with the bov's removed and blocked off. what i also noticed is now theres a bloody big pipe that goes all the way to the other side of the car and now its there for no reason and is just taking up space and boost pressure.
does ne 1 think this could b causing my loss of power down low as the car doesnt realy go ne where till bout 5000rpm.
is it worth putting bov's back on? romoving the pipe completely and blocking it off at the twin turbo pipe or just leavin as is?
Your problem is wastegate actuators. Not BOV's
I have no BOVs on my R32 gtr, i have a problem to where both the bov hoses which are located of the twin turbos joined together via a alloy pipe and hose clamped. Before this i had just the bov hose blocked on the air box side with a solid alloy block in the pipes and the car idled perfect for 1yr. Now i took all the bov steel piping out to clear for some custom intake ram air induction joined the two hoses together with alloy pipe and the idle hunts around and is a little rough down low in rpm range.
This doesnt make sense in theory they where blocked of before already only now i took out all the un necessary pipework and it behaves like this.
Did the original pipework create some balance of some sort i dont know can anyone shed some light on this please.
Cheers.
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
    • It was gonna take much longer for the 440cc so I'd thought I'd risk it with the 550cc. They finally arrived and I couldn't wait any longer (I could but I was quite excited after 2 months) and installed them myself. Removed the old injectors, inserted the new and connected everything up. Before starting the car, I tuned the injector size from the factory 270cc to 550cc using Nistune.   This did some of the calculations automatically which catered for the TIM. The latency however did not seem to change. Deatschwerks have the tuning data available for each injector online, and I had a look at it. It has a table which relates to latency according to pressure and voltage (see below image). Nistune requires the 14v value, but I am unsure of which pressure value to look at (my lack of knowledge and experience have something to do with this). The highlighted value is close to my current latency which is 760µs. It is for 14v which makes sense, and the pressure is 31.6 Psi.   I still gave the car a test drive to see how it goes, and honestly it has never felt so powerful before (and some people say the RB20DE is very weak?). I really enjoyed the drive. Side note; The injectors are quite noisy, which someone mentioned before. This does not really bother me however. I will still ask my mechanic to have a look at it and perhaps ask a tuner to fine tune it if they have the knowledge.
    • Also true. But imagine not wanting new injectors? Imagine wanting to use 30 year old injectors?
