Where Can I Get Interior Like This Done In Melb?
hey guys, i was just on ebay and i found this
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=tab%3DWatching
they make custom leather seat covers for whatever car you want and I was wondering if anyone knows where in melb does this kind of service as i cannot be bothered purchasing over ebay thanks
try ultimate auto trim
got mine from there and look fantastic
Yudian Sutopo - managering director
1/16 superior drive
Dandenong South
(03) 9768 2840
0433 113 911 - 0432 208 972
duno if mobiles have changes card is pretty old that i have
1/16 superior drive
Dandenong South
(03) 9768 2840
What were the prices like there?
i got in teh group buy a few years back cost me liek $650
but it was worth it
front seats, rear seats were covers
door trim, parcel shelf, gear shifter boot, and centre glove compartment had material for all it
might be a bit more cause that was the group buy proce but its worth it
the ebay add u just showed us the link of is the place GTS-T_SEDAN is talking about lol. I bought my interior for my honda from them in person even tho the add was off ebay. Send the guy a message on ebay make an appointment with him and he will meet u at the shop in dandenong. Thats what i did!!! ps: didnt u notice the username of the ebay add is ultimate auto trim? lol
a mate got some awesome ones for his audi to stop his dog from trashing the seats, they take the seat out and put a leather cover over it, i will try and get the details from him for ya
yeah the only problem with the dandenong place they cant do the skyline gt logo on it and that other place in hoppers i think they give it cheaper for SAU members and can do the logo on it to, hrmm has anyone dealt with the other place>?
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
