I got my car tuned and because the car started to missfire over 14psi it was tuned at 13psi. I have changed my sparkplugs and fixed up the coilpacks so i want to see if the missfire is still there under higher boost. Now what im wondering is would it be safe to run higher boost with the current tune? The engine has forgies and the turbo is a high flow that i have been told can handle 20psi easy. Could i just watch the knock sensor and if it starts to knock i how it's running to lean? I would like to be able to do this without having to fork out more money on a retune.
https://www.sau.com.au/forums/topic/258715-more-boost-after-tune/
I asked for the tune to be done on the highest psi. But it was tuned at 13psi because that was the "safest for the turbo and heat" but he told me he ran it up to 20psi and the ratio's were fine. After that i called him back and asked for the dyno runs and then he decided to tell me that anything over 13psi it had a missfire. The reason why im not running to get it retuned is he stuffed me around and a tune that should have cost $250 cost me over $2000. So im not going back to that workshop. And i went to another workshop and found that they were idiots too. These are both performance workshops. And the computer is std but i have a haltech intercepter connected that was tuned.
$2000!!!!!!!!!
What area are you in? Others on here can recommend good workshops to go to.
For the safety of your engine you should just go and have it checked for higher boost by someone in the know.
Consider investing in a PowerFC.
agreed, did not know u was only running a piggy back style ecu go for a pfc they cheap and will handle everything you need. but in general would it hurt to add a couple of psi? i'm only running 10psi off the gate no boost controller at all, i have a manual boost controller..can it hurt to add a few psi? i have an apexi turbo timer which shows hypothetical afr's and mine is always in 10-12 range (meaning lots of fuel yea?) so can it hurt to add some psi? Hame
p.s sorry for hijack!
Yea the $2000 is a very long story.... I live in canberra. And i would really like to get a powerFC but they sell so quickly.
But if anyone could recommend someone who can tune a haltech and is anywhere near Canberra please let me know. Or if anyone is selling a PowerFC for a R33 please let me know.
anyone?
Well the missfire is still there. So it must be the ecu cut is coming in at 14psi. How do i get around this without getting an aftermarket ecu? I really wish the dropkick that tuned my car told me about this.
Get it chipped
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
