More Boost After Tune
shotter
 Share
I got my car tuned and because the car started to missfire over 14psi it was tuned at 13psi. I have changed my sparkplugs and fixed up the coilpacks so i want to see if the missfire is still there under higher boost. Now what im wondering is would it be safe to run higher boost with the current tune? The engine has forgies and the turbo is a high flow that i have been told can handle 20psi easy. Could i just watch the knock sensor and if it starts to knock i how it's running to lean? I would like to be able to do this without having to fork out more money on a retune.
it a risk i guess but as long as you watch the knock sensor it should ok for a addition of a couple of PSI i would guess.
would like to know the answer from others too..Hame!
I asked for the tune to be done on the highest psi. But it was tuned at 13psi because that was the "safest for the turbo and heat" but he told me he ran it up to 20psi and the ratio's were fine. After that i called him back and asked for the dyno runs and then he decided to tell me that anything over 13psi it had a missfire. The reason why im not running to get it retuned is he stuffed me around and a tune that should have cost $250 cost me over $2000. So im not going back to that workshop. And i went to another workshop and found that they were idiots too. These are both performance workshops. And the computer is std but i have a haltech intercepter connected that was tuned.
$2000!!!!!!!!!
What area are you in? Others on here can recommend good workshops to go to.
For the safety of your engine you should just go and have it checked for higher boost by someone in the know.
Consider investing in a PowerFC.
agreed, did not know u was only running a piggy back style ecu go for a pfc they cheap and will handle everything you need. but in general would it hurt to add a couple of psi? i'm only running 10psi off the gate no boost controller at all, i have a manual boost controller..can it hurt to add a few psi? i have an apexi turbo timer which shows hypothetical afr's and mine is always in 10-12 range (meaning lots of fuel yea?) so can it hurt to add some psi? Hame
p.s sorry for hijack!
Yea the $2000 is a very long story.... I live in canberra. And i would really like to get a powerFC but they sell so quickly.
But if anyone could recommend someone who can tune a haltech and is anywhere near Canberra please let me know. Or if anyone is selling a PowerFC for a R33 please let me know.
anyone?
Well the missfire is still there. So it must be the ecu cut is coming in at 14psi. How do i get around this without getting an aftermarket ecu? I really wish the dropkick that tuned my car told me about this.
Get it chipped
If its an R33 RB25 ecu i wouldn't bother trying to get it chipped
Spend the $800-$1000 and get an Apexi FC
was going to go NISTUNE with my 33 GTR OEM ecu but i decided to just get a replacement PFC
 Share
    • I know there's been no posts for 3 years, but figured it wasn't worth starting a new thread for my question. The nice Japanese lady in my V36 occasionally/randomly speaks to me whilst I'm driving.  Of course my Japanese is very rusty, I'm guessing it's to do with the Nav system? Anyone have knowledge on this?
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
