Hello fellas,
I need someones opinion on this one..
I had a look at my underbody piping a month ago during a minor service and found that the Flexi Joint/pipe has been scraped pretty good. The metal mesh stitching has been scraped good that the rings have now been exposed and slighty scratched... but good thing is that there is no leak to it...... as yet. (ive only had the car for 5 months and i hardly scrape it.. hell i dont know what the previous owner in japan did to it..)
so i had a look at ebay for some pipes and found this Y pipes. now, my question is.. is this the right and perfect ones that i need if i go ahead and change the current pipe on my ride?..
wont be to short wont be to long?... everything is stock on my exhaust system, i failed to take photos and measure when i had the chance to.. so forgive me on this one... i just thought to ask some experts out there as i cant wait til my next service to have a look at it..
anyway appreciate your help and thanks in advance.
https://www.sau.com.au/forums/topic/258748-underbody-piping/
yeh i read about extensions for this things... hmm might get Hi-Tech Mufflers Sydney to check it out..
If you're going to HiTech anyway, why not get one of their Y pipes?
Their bends are a lot more gentle:
And you can get them to make an extender that turns the 2 pipes into a single, and mate up with your single mid pipe.
sweet.. thanks scathing.. looks kinda better in a way. do you know around how much it would cost me to do this with Hi-Tech? i just want to replace this particular pipe and not the entire exhaust. (i do not like it loud)
Also, by looking at the picutre, the flexi joint doesnt necessarily need to be there?.. just out of curiosity..
Thanks mate for the info.
The flex joint isn't mandatory, but it is recommended.
I cracked my exhaust in 3 places (exit flanges for the cat, and the mid muffler) when I slid off the track at Wakefield, and bashed the exhaust on a ripple strip. I'm not sure if flex piping would have saved it, but it wouldn't have hurt either.
As for cost, no idea. The pipe isn't exactly complex, and the extension won't be that hard either.
At least you were trying...
As for Flex pipes, most muffler places would be able to fit them, different sizes are available.
To give you some food for thought, a good catback exhaust does not make the car loud.
When I put my HiTech on and left the rest stock, my car sounded as quiet as stock up until 3000RPM. I picked up a bit of volume and a more growly note higher than that, but it wasn't noisy. Your only problem is that it dones between 1900-2200RPM, which is 60km/hr in 6th gear. Drive at 70 around town, and you'll be fine (although cops may not feel the same way).
If you can afford a Fujitsubo Legalis-R, it has the same RPM attributes with a slightly more aggressive note up top.....and no drone. Definitely worth the money if you can afford it.
The APS exhaust is about as quiet (its noise legal with the turbo kit, not sure if it is without the turbines providing an extra muffler), but a true dual isn't the best option for a NA road car.
If the HiTech and Fujitsubo aren't noise legal, they're close enough (and look stock enough) that no cop would give you a hard time over it. Just don't do extractors and high flow cats, and you'll be fine.
The difference in peak power output between the exhausts I mentioned above, and the noisy ones, on an otherwise stock car is sweet FA, so you're not really losing out either. I'd just avoid the true dual ones, so you don't lose midrange torque for practically no gain up top.
Thanks for the tips Scathing. learnt something new.
ill visit HiTech soon in the next week or so and see what they say in terms of that middle pipe. if they offer me something outstanding with the exhaust i might consider..but we will see first and let you know the offer.
now all i want to find out is the $$$ figure. but should be okay.
Thanks again man..
Can you please provide more explanation on the above statement?
can someone provide some suggestion on HKS legamax and Kakimoto 06&R catback? Similar price range like Fujitsubo, but which better??
or even Borla, which isnt loud, but sound better (a little louder, deep) than stock?
arrggg, too much choices..
Too much cross sectional area. You're basically running an exhaust too big for the engine (and, before some bright spark chimes in, that doesn't mean it has "too little backpressure").
I've run my car back to back with another owner when our only powertrain mods were the catbacks. His APS true dual pulled 2rwkW more than mine, but had lost a noticable amount in the midrange. You could feel it on the road, as well.
The HiTech guys tested several exhausts of differing shapes and sizes (they had access to Nathan Pilkington's grey import GT-P 350Z) and settled on the design they have - 2.5" Y pipe into a single 2.5" mid pipe - as the best "total area under the curve" option.
Of course, if you use the APS exhaust the way it was intended (i.e. with their twin turbo kit) then it works a lot better than an exhaust that goes into a single pipe.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
