hey there,
just taken out my NGK BKR7E that have been gapped to.5, my mechanic has ordred me bosch plugs to replace them. what should i gap them too?
RB26 about 500hp, 18lbs boost, read that the bosch plugs arent that good?
cheers robbie
https://www.sau.com.au/forums/topic/258766-spark-plugs/
hey there,
cheers robbie
NGK all the way, i use r5671A-8 which is a not protruded plug.My rb20 makes 299rwkw on 1.5bar(20lbs)i keep the gap they come out of the box .8mm an no problems. Ialso used the same plugs in my hk ute with a blown 400 sbc an that made 727rwhp.On the part number for the plugs r5671a-8 the -8 is the heat range
https://www.sau.com.au/forums/topic/258766-spark-plugs/#findComment-4448439
Don't get bosch.. they are not good spark plugs for the RB26.
i have NGK BCPR7ES which come standard set to 0.8. leave them at that and the car will run great.
Edited by SuperElectric
https://www.sau.com.au/forums/topic/258766-spark-plugs/#findComment-4449272
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
