  • Replies 489
20psi yeah? did you guys have a chat about boost level on stock internals?
yeah my limit is still 20 for reliability sake but on a bigger turbo like this it is still ultra efficient so the head room is higher than say a high flow at the same boost. (the point of diminishing return).
I would be happy on E85 to push probably another 20-30rwkw out of hamish's car for dyno queen status but we really wanted a direct comparo @ the same boost.
Oh and prepare your self for an sms daniel :D i hear you want to play dyno's on friday.
Edited by URAS
hahahah, me????? of course not... :D
Stao will be happy, he's always telling me to run 30psi :)
haha 30psi rolls off stao's tongue too easy :) if only it was soo easy.
Edited by URAS
aahh... interesting
seems like run of the mill oils car manu's don't have issues with.. but it seems the high end oils aren't necessarily suited.... interesting
i should probably do an UOA on the Amsoil when i change it next
what boost control are you running?
i would have expected boost to hold up better with E85 due to the increased combustion gas due to extra fuel?
did you find that the engine runs a lot cooler? EGTs will be cooler
its good to see some comparision maps on a dyno that can't wheel slip..
the tests we have done at work with a GTRS on a stock SR20de+t with E85 found that even with LINK G4 ecu and boost control (i think its called vipec over there) we couldn't stop boost creaping up from 14-16psi from approx 5700rpm although we think the internal gate was the limiting factor with that turbo.
now hes running a GT2876R and a 38mm wastegate with no issues.
I'm hoping that early next year i can get my car tuned at my workshop on E85 once my fuel system is up to scratch. 324kw on 98 pump gas on 19psi on a stock rb25 on a dynapack dyno would be interesting to see what gains there is on my setup.
best part is i can have a simple switch that can switch my fuel, inginition, boost tables to suit the E85
worst part is theres no E85 on the pump in NZ. and its approx $2.5 per ltr here. 98s expencive enough at $1.82atm
sinthetic oils are what iv been told to run. 5w30 for street cars and 0w30 for race cars if its too thick the oil pressure is to high even when the car is up to operation tempature.. we have been using elf oil in the ones we have done..
im running a blitz dsbc spec s (the single solenoid one) and i'm guessing that's where the boost is going
not concerned at al tho... having 2psi less @ 7000rpm is pribably a good thing :D
would be nice to be able to flick a switch.... i think the only way i could do thoat with the pfc is to physically have 2 :(
good news guys!
as halle informed me, e85 is now available at the pump for 109c @ fueltown southland!
i have contacted the store and spoken to the manager, and the fuel is supplied by powerplus. the fuel is also a 91/ethanol blend like united's
http://www.powerplusfuel.com.au/
after speaking to geoff, he informed me that getting the fuel from csr was impossible as the big fuel companies have signed contracts for the next 6 months preventing anyone else purchasing e85, however they are not using it themselves... and the contracts are probably going to get renewed.
the fuel, is selling at a rate of only 300l per week, so c'mon guys, lets go help 'em out!
i'll be filling up and testing later this week, and will post results when done.
good news guys!
hmm not too far, might swap cats over to E85. Was going to mix up my own 98 and methanol but i may try the pump gear first. We made just shy of 430 on 98 so it should be a good laugh on e85 or a jungle juice.
Oi hamish when you get a min drop past and we will look at the fuel economy.
are you ready for the E85 on-slaught Trent?! :D all the east-siders will be wanting tunes now.
Guess who lives 5mins from Fueltown Southland :P:blink::)
I feel this must be represented in picture form, to illustrate the awesomeness of what has just occurred...
Point A = new E85 source
Point B = essentially where i live
Point C = old E85 source
It's karma i reckon :D
My E85 trips have been cut by a whopping 90%! It's almost exactly 1/10th of the distance to get E85 now!
:banana::banana::banana::banana::banana:
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it    Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher      I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
