  • Replies 489
20psi yeah? did you guys have a chat about boost level on stock internals?
yeah my limit is still 20 for reliability sake but on a bigger turbo like this it is still ultra efficient so the head room is higher than say a high flow at the same boost. (the point of diminishing return).
I would be happy on E85 to push probably another 20-30rwkw out of hamish's car for dyno queen status but we really wanted a direct comparo @ the same boost.
Oh and prepare your self for an sms daniel :D i hear you want to play dyno's on friday.
Edited by URAS
hahahah, me????? of course not... :D
Stao will be happy, he's always telling me to run 30psi :)
haha 30psi rolls off stao's tongue too easy :) if only it was soo easy.
Edited by URAS
aahh... interesting
seems like run of the mill oils car manu's don't have issues with.. but it seems the high end oils aren't necessarily suited.... interesting
i should probably do an UOA on the Amsoil when i change it next
what boost control are you running?
i would have expected boost to hold up better with E85 due to the increased combustion gas due to extra fuel?
did you find that the engine runs a lot cooler? EGTs will be cooler
its good to see some comparision maps on a dyno that can't wheel slip..
the tests we have done at work with a GTRS on a stock SR20de+t with E85 found that even with LINK G4 ecu and boost control (i think its called vipec over there) we couldn't stop boost creaping up from 14-16psi from approx 5700rpm although we think the internal gate was the limiting factor with that turbo.
now hes running a GT2876R and a 38mm wastegate with no issues.
I'm hoping that early next year i can get my car tuned at my workshop on E85 once my fuel system is up to scratch. 324kw on 98 pump gas on 19psi on a stock rb25 on a dynapack dyno would be interesting to see what gains there is on my setup.
best part is i can have a simple switch that can switch my fuel, inginition, boost tables to suit the E85
worst part is theres no E85 on the pump in NZ. and its approx $2.5 per ltr here. 98s expencive enough at $1.82atm
sinthetic oils are what iv been told to run. 5w30 for street cars and 0w30 for race cars if its too thick the oil pressure is to high even when the car is up to operation tempature.. we have been using elf oil in the ones we have done..
im running a blitz dsbc spec s (the single solenoid one) and i'm guessing that's where the boost is going
not concerned at al tho... having 2psi less @ 7000rpm is pribably a good thing :D
would be nice to be able to flick a switch.... i think the only way i could do thoat with the pfc is to physically have 2 :(
good news guys!
as halle informed me, e85 is now available at the pump for 109c @ fueltown southland!
i have contacted the store and spoken to the manager, and the fuel is supplied by powerplus. the fuel is also a 91/ethanol blend like united's
http://www.powerplusfuel.com.au/
after speaking to geoff, he informed me that getting the fuel from csr was impossible as the big fuel companies have signed contracts for the next 6 months preventing anyone else purchasing e85, however they are not using it themselves... and the contracts are probably going to get renewed.
the fuel, is selling at a rate of only 300l per week, so c'mon guys, lets go help 'em out!
i'll be filling up and testing later this week, and will post results when done.
good news guys!
hmm not too far, might swap cats over to E85. Was going to mix up my own 98 and methanol but i may try the pump gear first. We made just shy of 430 on 98 so it should be a good laugh on e85 or a jungle juice.
Oi hamish when you get a min drop past and we will look at the fuel economy.
are you ready for the E85 on-slaught Trent?! :D all the east-siders will be wanting tunes now.
Guess who lives 5mins from Fueltown Southland :P:blink::)
I feel this must be represented in picture form, to illustrate the awesomeness of what has just occurred...
Point A = new E85 source
Point B = essentially where i live
Point C = old E85 source
It's karma i reckon :D
My E85 trips have been cut by a whopping 90%! It's almost exactly 1/10th of the distance to get E85 now!
:banana::banana::banana::banana::banana:
