well my faithful clutch finally started slipping... :(
after 2 years of 300rwkw and 5 years of 180rwkw, hundreds of launches and thousands of kicks, the mystery box that came over on the boat will finally get opened...
hopefully i will get it sorted before DECA :down:
  • Replies 489
lol... it was an exedy heavy duty... how the hell it lasted through all that is beyond me!
have an exedy cushion button single going in tomorrow... so i will FINALLY get to make propper use of trent's ethanol tune @ DECA!
will report back after :blush:
It had the GTR nismo number on the clutch plate, bit better than the run of the mill rb25 item they supply in the normal rb25 kits.
I havent read this whole thread, to much for me whilst i am at work, but i can announce that Caltex will be making E85 to fuel Holdens new Commonwhore and we aim to have 100 servos selling it in the next 12 months.
!!!!! AWESOME !!!!!!
Possibly a silly question for me to ask, but I have no idea...something tells me the answer is no...
Can you tune a rotary to run E85? I don't know how much advanced timing you could add lol..
Thanks, back on topic! I will definitely join the bandwagon when this goes ahead, should be getting better money by then to afford real mods too :P
any ideas where caltex will be getting their e85 from?
i.e. is it manildra or csr?
i have a full tune for both fuels sitting here anyway... but the difference is enough that you cant go swapping all over the place
my guess is that its gonna be manildra as i'm fairly sure that united have an exclusive deal on the CSR stuff, which suits me to a tee as the manildra seems to be better anyway :P
also might add, the the new clutch went in @ 23:30 Thursday and was on the track @ DECA on Saturday... (got 500k's driving on it to bed it... inc 100km stop start traffic)
went for an exedy "HHHDBC... and am very happy with it...
its very livable on the street, with a nice pedal feel for the power its made for and launching/shifting is a dream
it was my first track day with e85 and it was an absolute blast!
the car was SUPER responsive and you can really feel the difference over PULP :P
:D totally getting on this!
who do you work for ido09s?
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
