to be honest this kinda worries me....
i'm running 300+rwkw on standard internals and hence cant really afford any inconsistencies in my fuel... as with many of us here.
i'm happy to use minaldra/powerplus as i am of the opinion that their qulaity control will be spot on as they are a dedicated race fuel manufacturer.
there are 2 main points that concern me
1) with caltex making their own recycled ethanol from various waste products, what will the quality/consistency be like? on the caltex news section it said they are going to make fuels with up to 85% ethanol.... now this could mean either that the ethanol content is going to be around 85% or simply that they will also be making e10 etc in the same plant. To run a stock v6 commo, there is a fair tolerence in fuels before detonation will occur.
2) i'm worried that people are gonna blow their motors up. for example, say you tune on manildra @ 106 octane, and then throw in some CSR 104 octane and go smashing it around without a hand controller or any knock warning device... its the same as running a 98 tuned skyline on standard 95 octane. with caltex bringing a third fuel to te game, this could further increase chances of this....
at this stage, i'm going to keep using manildra fuels only until i can receive some confirmation on the caltex fuel :(
  • Replies 489
I am not a chemist so i cant really go into details, but apparently Ethanol is not a great winter fuel and therefore Caltex will be following worldwide practice by making the winter mix contain more PULP, hence the 70% (winter)-85% (summer) ethanol mix.
I know for a fact that if i run our E85 i will be having 2 tunes, summer and winter.
If i were you i think i would be more concerned at the fact your supplier hasnt given you this information. I guess we all need to see how E85 reacts in winter and go from there.
at this stage, i'm going to keep using manildra fuels only until i can receive some confirmation on the caltex fuel :banana:
Geez you worry too much, you could run a 50% mix with all the det protection! I'd like to hear from any tuner who has managed to get this gear to knock at all, there are national standards set if you produce/sell this stuff, there not back yard company's!!!! Lol.
and whats this bagging CSR sh*t, they have made a big investment to produce it here in Oz and I for one am very happy they have.
Where your comparison's done on the same day, same dyno, same air temp, same age batch, was there a big enough percentage difference in power to exclude all these variables? I dont think it's fair to say one's better than the other unless you have done this!
i'm not saying CSR is shit at all... its a brilliant fuel
i just prefer the manildra stuff :)
i used 10% less fuel and 5deg less timing to get the same power... (and the same result with daniel's car)
same tuner, same dyno, same weather (roughly), both fuels purchased on the day of tune, but on a different day ;)
its true that it wont knock, and i'm not really worried as such, i just happen to live near the servo and might as well use exactly what the car is tuned for
I agree with the Powerplus, We tried a few different brands with our Race cars and non came close to Powerplus in both IP and Sportsedans
Kingscorps IPRA S14A racecar in round 1 at Wanneroo this season had number 3 Cylinder liner sink letting the gasket blow with massive water loss and over heating the result, The problem was there from qualifying but we needed the points so we decided to go for it and get what points he could, He had old tyres from last year and still won the meeting and set the lap record.
After stripping the engine every part was still in good condition and is now in a fresh block, Im sure the fuel saved the engine.
the reason E85 is capped at 85% is the fact any less than 15% pulp makes the cars a real cop to cold start.
Biobutanol is my latest fixation.
really? just had a quick wiki.... about 96 RON, bit more stable in terms of water contamination and less corrosive than ethanol but wouldn't you lose all the goodness of knock properties of the E85?
and doesn't seem like it would make more, or even the same amount of power as E85?
this is just what i gleamed from a quick wiki glance, so could be way off the mark.
  • 3 months later...
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
