  • Replies 489
i need a pfc i only get 300 to a tank if im lucky an thats conservative driving... i get better fuel economy on the freeway though
Yeah standard ECUs suck balls for economy.
Id be intersted to see this goes on a built engine...say one already running 21-22psi.
I wouldnt want to push anymore boost into it but maybe some more timing if E85 permits. It reckon it would be cool to have a E85 tune to the magic 400 just for dyno nights and things like that...
  • 3 weeks later...
too much to commute to Hoppers just to get fuel??
with chopping and changing, do you have to wait until you're as close to empty as possible, and then fill up with 98 before switching tunes?
with chopping and changing, do you have to weight until you're as close to empty as possible, and then fill up with 98 before switching tunes?
that would make sense....
just roll into the servo on the smell of an empty rag and refill....
or just take jerry's and do it at home.... remove the return line from the injector rail and let car idle... doesn't take long with a good pump.
well after a month on e85 i'm back on pulp for a little while... for the great ocean road cruise at least
and i'm not really loving it ;)
the car has a massively noticeable power loss, but it does start and idle way better :P
didn't check the fuel filter as everything is running 100%
but its not all bad news.... i did put in a new diff so that i could enjoy my lower power a bit more... and i'm happy as!
Real shame this stuff isnt as common as pulp.
I dont know about you guys, but there's NO WAY im having a jerry can in the back during spirited/mountain drives (on current tune, low boost, i need a fill of 98 just to get back to Sydney after a 45min run - mind you there's a lot of WOT involved). On a car that not exactly fuel friendly to begin with (370kw atw), its just not a viable option until the fuel is stocked at a lot more servos.
fair enough. i too am contemplating the practicalities of it all with Hoppers being the only place.
Trent @ Status said he could give me both maps on a USB drive and i can chop and change when i want, but it does seem to require a bit of forward planning, especially with long trips like Apollo bay.
If you still had E85 in there, you'd almost have to have a little bit of 98 with you... wait to you're practically empty, put in the 98 can, switch tunes and use the 10 or so litres of 98 to get you to a petrol station.
how much E85 do you get in one go? i take it you just don't head over the bridge just to fill up and not take any extra
nah mate its easy..... i go to hoppers and get a full tank & 2 jerry's - so that's 100l / $100
i just remove the return line from the rail (1 phillips head screw) and let the petrol flow into another jerry.... takes about 2 mins to drain the last 1/4 of a tank.
then fill tank and jerrys, turn on pfc, load map, and drive away happy...
alternately you could wait till the light comes on but i prefer to have 100% correct fuel in my tank :P
don't think this is Australia wide as United website has dropped the SA locations but Vic and NSW remain
http://www.unitedpetroleum.com.au/distribu...5-locations.asp
maybe it's just banned in SA? hope so.... (no offence :banana:, we can run a smuggling ring across the border :banana:)
but seems a bit strange with the new E85 commonwhore coming out, Holden was saying the fuel will be widely available... :banana:
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
