  NXTIME said:
nice...best of luck for next Friday.
Oh, and I noticed the irony of your ANDRA race number.... :P
Back on topic...Anthony Maatouk is up there with the best RB30's in the world: 8.1@171MPH all on a 10.5" tyre. Even batter is the fact that the car has laid down 1080rwhp with a single cam.
Yeah 3030 is a bit of a giggle. Joe Signorelli is 2929...does that make me 1 better than him?
I wish i had a 3030 so i could crack off a few shells.
Here's a pic of my old racecar before the 'twoogle' days
Edited by DiRTgarage
  • Replies 285
  R31Nismoid said:
Im not talking about Getrag's in the R34 GTR.
The typical 10-15yr old box in R32/R33's that do fail.
These are in circuit, street, whatever. Come onto boost in 3rd - pop. Plenty of times and the street cars are the saddest of all really... plenty of threads over the years about stripped boxes.
I agree with the above. My car, (Tomei stroker twin GT-RS's) stripped a 11,000 Km old gearbox to bits. I have ALWAYS been careful of 3rd.... and the gear change which it happened on was not a very hard change at all. Lets see how the OS giken + input shaft + billet centre plate goes! Im half expecting my front diff to go pop.
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
