  • Replies 40
Yeah, I have found WRX's are either slightly modified or heavily modified. They have crap gearboxes and driveshafts, so you usually see close to stock examples (FMIC, Filter, Exhaust etc) to Extreme versions (over 260KW - These require strengthened boxes, stonger driveshafts, Engine Internals etc etc) - This really is a testament to the quality of Skylines.. My r33 is Heavily modified (Forgies, HKS turbo, FCONV, etc) but the gearbox/driveshaft is totally stock and coping easily...
Long Live the skyline!
https://www.sau.com.au/forums/topic/25881-r33-gtst-vs-wrx/#findComment-548918
beat a 2001 wrx yesturday. there launch is nearly unbeatable. i have only had the car for 4 or so weeks so im still learning but my gear changes i thought were pretty decent with small chirps right up through 3rd pulled away quite easy at top of 3rd.
won quite easy in the end
https://www.sau.com.au/forums/topic/25881-r33-gtst-vs-wrx/#findComment-549533
had a run with a rex last night, we both cruised off the mark, then went for it through first and second. when i threw her into second i started pulling carlenghts on him. Hahaha so funny, then he pulls up next to me with his chick in the car (who was looking over smiling) and goes 'oi, mate, my other car would smash that thing'. me and my mate just wound the window up on him as he kept talking. hahahahaha
https://www.sau.com.au/forums/topic/25881-r33-gtst-vs-wrx/#findComment-551657
yep with few mods and good launch Rexs are damn quick!
doesnt take much to get them into 12s.
rexs or GSRs that you guys have beaten are the one with shi t drivers. or they are relitively stock while skylines have around
220KW at the fly like most our cars do.
but belive me with good drivers and mild mods like 3"zorst and FMIC they will launch about 2 car length and may hold the gap until 400m mark against us.
allthis info are from pure experience myfriends :P good ol days
https://www.sau.com.au/forums/topic/25881-r33-gtst-vs-wrx/#findComment-551850
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
