  • Replies 40
Yeah, I have found WRX's are either slightly modified or heavily modified. They have crap gearboxes and driveshafts, so you usually see close to stock examples (FMIC, Filter, Exhaust etc) to Extreme versions (over 260KW - These require strengthened boxes, stonger driveshafts, Engine Internals etc etc) - This really is a testament to the quality of Skylines.. My r33 is Heavily modified (Forgies, HKS turbo, FCONV, etc) but the gearbox/driveshaft is totally stock and coping easily...
Long Live the skyline!
https://www.sau.com.au/forums/topic/25881-r33-gtst-vs-wrx/#findComment-548918
beat a 2001 wrx yesturday. there launch is nearly unbeatable. i have only had the car for 4 or so weeks so im still learning but my gear changes i thought were pretty decent with small chirps right up through 3rd pulled away quite easy at top of 3rd.
won quite easy in the end
https://www.sau.com.au/forums/topic/25881-r33-gtst-vs-wrx/#findComment-549533
had a run with a rex last night, we both cruised off the mark, then went for it through first and second. when i threw her into second i started pulling carlenghts on him. Hahaha so funny, then he pulls up next to me with his chick in the car (who was looking over smiling) and goes 'oi, mate, my other car would smash that thing'. me and my mate just wound the window up on him as he kept talking. hahahahaha
https://www.sau.com.au/forums/topic/25881-r33-gtst-vs-wrx/#findComment-551657
yep with few mods and good launch Rexs are damn quick!
doesnt take much to get them into 12s.
rexs or GSRs that you guys have beaten are the one with shi t drivers. or they are relitively stock while skylines have around
220KW at the fly like most our cars do.
but belive me with good drivers and mild mods like 3"zorst and FMIC they will launch about 2 car length and may hold the gap until 400m mark against us.
allthis info are from pure experience myfriends :P good ol days
https://www.sau.com.au/forums/topic/25881-r33-gtst-vs-wrx/#findComment-551850
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
