Pss Presents: Tech 9 Tyres Bikini Car Wash And Show'n'shine
Come on down on the 15th of March to the Tech 9 shop to browse some of Perths hottest rides on display as well as some gorgeous women washing you car to the beats of DJ Jordan and DJ Benny T playing live.
Bikes - $10
Cars - $20
4x4's - $25
All cars washed will go into the draw to win a set of 20" rims supplied by Tech 9!
Food and drinks will also be on sale!
Check out our website for more details and the......other poster lol
yeah might cruise down after the sauwa meetup.
when do u think the sauwa meetup will finish coz also on this day is a sq comp at westside car audio
Guys going to be a huge turnout and great prizes to win also great talent,
Wouldnt miss it, So try to get your Bottom's Down and have some fun and make friends with everyone in the Perth car scene.
PSS (Perth Street Scene) is for all makes of cars and bikes. Check them out at perthstreetscene.com.
Not sure if I can make this one, I gotta work ;). Couldn't make the last one cos I was too hungover. I'm not doing to well! :blink:
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
    • How will O2 sensor voltages help to identify it when it is sputtering?
    • What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot.
