well its not a r33 or r34 motor its actully a r32 im very lucky to cum across this motor well i bought this motor 4 6k they said its got nismo turbos meatal head gasket and cams so i told them no worrys ill take it i bought about 6k of parts for it ecu,coil packs etc no internals as i was taking it all apart so i could paint it up at work i found adjustible cam gears thort cool as we were putting the timing belt kit on we noticed the crank was moving back and forth 3 to 4mm so i ordered big end bearing and conrod bearings wen we went to chang the bearing we took the sump off and found all the goodies forged pistons conrods r33 balanced crank and a grex oil pump the old bearing were nismo items so yea sounds a bit to good to be true but it happened
good stuff, thats what i ,meant by not throwing in a second hand engine in without checking it... its lucky you got a good engine to start wiv, my conversion cost so much coz ive got a fairly big engine setup, thats where it costs the most...
good result, mine is weeks away from completion and i cant wait to drive it...
same cant wait to take it down the strip and see wat i can get with street tyers hoping to get into the 12s and it left alice springs today so hopfully be at boost worx next week to get finished
1 more question will it be loud as i dont hav any cat mufflers or any thing its just stright pipe pretty much i no its illegal but in this town cops r pretty cool they dont mind it as long as u got good tyers and u dont act like a wanker in town they dont really care wat u got dun to ur car
i have to moove to your town... wonder if theyd pull u over for max boost gate open!!!
you should run 12s easy,maby 11's, i ran 13.0 in my old s14 with only 14 psi, exhaust and a clutch with bald tyres...
it probably would be loud but not massivly....
  • 1 month later...
  • 4 years later...
A mate did a similar conversion and I'm pretty sure he used these guys I've linked below; my mate basically sent the original RB25 loom across with the RB26 loom and the guys modified it and sent back the modified loom. They were super helpful and the car started first turn of the key. Didn't cost much either from memory.
http://www.sideshows.net.au/contact/
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
